ISRG2 GRE Tunnel and VRF
I have a serious problem bringing up an GRE Tunnel combined wir vrf-lite funktion. A 2951 Version 15.0(1)M3 with fixed internet uplink has a tunnel to a 2811 12.4(13r)T with PPPoE session (fixed IP).
without VFR everything seems to be ok:
C2951C2811
interface Tunnel12
  description Tunnel_PPPoE_nach_Buchhandlung
  bandwidth 2000
  ip address 10.1.12.17 255.255.255.240
  keepalive 10 2
  tunnel source A.A.A.A
  tunnel destination B.B.B.B
  tunnel path-mtu-discovery
interface FastEthernet0/1/0
  description Anschluss DMZ Telekom-Router
  bandwidth 34000
ip address A.A.A.A z.z.z.z
  ip nat outside
  ip virtual-reassembly
  ip tcp adjust-mss 1400
  duplex auto
  speed auto
ip route B.B.B.B 255.255.255.255 A.A.A.GW
interface Tunnel2
  bandwidth 2000
  ip address 10.1.12.18 255.255.255.240
  keepalive 10 2
  tunnel source B.B.B.B
  tunnel destination A.A.A.A
interface FastEthernet0/0/0
  bandwidth 2000
  no ip address
  duplex auto
  speed auto
  pppoe enable group global
  pppoe-client dial-pool-number 10
interface Dialer2
  ip address negotiated (get fixed B.B.B.B)
  ip mtu 1456
  ip nat outside
  encapsulation ppp
  dialer pool 10
  dialer-group 1
  no cdp enable
  ppp authentication chap pap callin
  ppp chap hostname xxx
  ppp chap password xxx
  ppp pap sent-username xxxx
ip route 0.0.0.0 0.0.0.0 Dialer2 200
status of int tu12: UP
status of int tu1 2:UP
OK, this looks good.
no I try to bring in VRF:
Header 1Header 2
ip vrf INTERNET
description Public-IP-Traffic
rd 1:1
route-target export 1:1
route-target import 1:1
interface Tunnel12
bandwidth 2000
keepalive 10 2
tunnel vrf INTERNET
bandwidth 34000
ip vrf forwarding INTERNET
ip nat outside
duplex auto
speed auto
ip route vrf INTERNET 0.0.0.0 0.0.0.0 A.A.A.GW
interface Tunnel2
bandwidth 2000
keepalive 10 2
bandwidth 2000
no ip address
duplex auto
speed auto
interface Dialer2
ip mtu 1456
ip nat outside
encapsulation ppp
dialer pool 10
dialer-group 1
no cdp enable
status of int tu12: UPstatus of int tu2: DOWN
It should work but...
I try to bring ing VRF to be able to externally ping A.A.A.A
Does anybody have a idea?
/br
Thomas
Peter Paluch
Thomas,
When you have the VRF configured on your C2951, can you at least ping the B.B.B.B address from C2951 using the command ping vrf INTERNET B.B.B.B? Also, can you ping A.A.A.A at the same time from your C2811?
Best regards,
Peter
Hi Peter,
yes ping vrf is working.
/br Thomas
