ASR1000-X Encryption Throughput
hotpackets
I'm looking at an ASR1K-X with an ESP40. Datasheets shows up to 12Gbps encrypted aggregate throughput.
If I exceed those numbers, is there a command that would show drops that occurred due to hitting encryption/decryption limits?
Is it QOS aware? With encryption happening before queuing and scheduling, would it still encrypt/decrypt PQ1 and PQ2 packets first?
Cristian Matei
   This is the command you're looking for, as you're looking for data-plane drops: "show platform hardware qfp statistics drop". Take  look at this document for further reference:
https://community.cisco.com/t5/security-documents/troubleshooting-vpn-issues-on-asr-where-to-start/ta-p/3113897
Cristian Matei.
5 Replies 5
Joseph W. Doherty
"With encryption happening before queuing and scheduling, would it still encrypt/decrypt PQ1 and PQ2 packets first?"
I don't know for sure, but doubt it would. I suspect encryption/decryption is FIFO.
That's my suspicion, but I wanted to see if anyone knew for sure.
I received confirmation from a Cisco engineer that the crypto module will indiscriminately drop traffic when its capacity is exceeded.
Cristian Matei
Cristian Matei.
Thanks! That document appears to have what I'm looking for.
