ASR1001-HX crash: Critical process ezman fault on cc_0_0 (rc=134)
yacine feniche
Hi Cisco Community
I'v faced a problem on my ASR 1001-HX in its17.3.4a IOS-XE Software which reloaded automatically
The Last Reload Reason when I issue show version command is "Critical process ezman fault on cc_0_0 (rc=134)"
Any one faced this problem before ?
No further information found on Bug Search Tool.
here are some tracelogs just before reloading
Router-1_RP_0 ezman[26377]: %EZMAN_CLIENT-2-ECC_DOUBLE_BIT_ERROR: Double bit ECC errors observed. NP (CC card) is going to be reloaded to recover
Router-1_RP_0 audispd[382]: type=ANOM_ABEND msg=audit(1714121459.729:89): auid=4294967295 uid=0 gid=0 ses=4294967295 subj=kernel pid=26377 comm="ezman" exe="/tmp/sw/mount/asr1000-elcbase.17.03.04a.SPA.pkg/usr/binos/bin/ezman" sig=6 res=1
Router-1_RP_0 root[28479]: %PMAN-3-PROCHOLDDOWN: The process ezman has been helddown (rc 134)
Router-1_RP_0 pvp[28532]: %PMAN-0-PROCFAILCRIT: A critical process ezman has failed (rc 134)
Thanks.
6 Replies 6
balaji.bandi
Looks for me Bug, upgrade to 17.9.4a and test it
BB
Thank you balaji.bandi for your feedback.
The problem occured once for the moment and I can't reproduce it at will.
I'm waiting for some other feedbacks or bug références. Otherwise, I'll open a case at Cisco support.
APERÇU
Hi @yacine feniche , I have the same issue on my ASR1002-HX WIN ios 17.9.3a .
One year ago, I detected something similar like "silent reboot" and I just made a  upgrade fo IOS !!
I´m waiting for cisco support request too!
Good Luck!
Upgrade to 17.9.5 and test it
BB
Hi Bajai, thank for your support !! I wll try update but, Did you already tested?
yes we are running 17.9.5 - in production.
BB
