04-06-2020
02:28 AM
- last edited on
11-03-2022
10:27 PM
by
Translator
I've got ASR router equiped as follows
NAME: "Chassis", DESCR: "Cisco ASR1001-X Chassis"
PID: ASR1001-X
NAME: "module 0", DESCR: "Cisco ASR1001-X SPA Interface Processor"
PID: ASR1001-X
NAME: "SPA subslot 0/0", DESCR: "Built-in GE SPA with 2 port 10G and 6 port 1G Interfaces"
PID: BUILT-IN-2T+6X1GE
NAME: "module R0", DESCR: "Cisco ASR1001-X Route Processor"
PID: ASR1001-X
NAME: "module F0", DESCR: "Cisco ASR1001-X Embedded Services Processor"
PID: ASR1001-X
I'm not able to install new software. Can somebody tell me what I'm doing wrong?
ERR-R02#install add file bootflash:asr1001x-universalk9.16.12.03.SPA.bin
install_add: START Mon Apr 6 11:14:56 cest 2020
install_add: Adding PACKAGE
--- Starting Add ---
Performing Add on Active/Standby
[R0] Add package(s) on R0
[R0] Finished Add on R0
Checking status of Add on [R0]
Add: Passed on [R0]
Finished Add
SUCCESS: install_add Mon Apr 6 11:15:12 cest 2020
ERR-R02#install activate file bootflash:asr1001x-universalk9.16.12.03.SPA.bin
install_activate: START Mon Apr 6 11:15:26 cest 2020
ERROR: install_activate: Nothing to activate.
install_activate:
For SMU activation, please specify the SMU to be activated.
Usage: install activate file smu_name.
For image installation, please make sure image has been added.
Usage: install add image_name followed by install activate.
For ISSU upgrade, please specify the issu keyword.
ERROR: install_activate exit(2 ) Mon Apr 6 11:15:52 cest 2020
Solved! Go to Solution.
04-06-2020 03:07 PM - edited 11-02-2022 02:52 PM
Thanks. The output is very helpful.
IOS-XE is currently loaded in Bundle Mode. Use the command below to unpack the file.
request platform software package expand file bootflash:asr1001x-universalk9.16.12.03.SPA.bin over verb
Don't forget to change the boot variable statement to point to the "packages.conf" file.
conf t boot system flash bootflash:packages.conf end wr
When this is all done, post the complete output to the following commands:
more bootflash:packages.conf | i SPA.pkg sh boot
Hope this helps.
Cisco ISR & ASR 1k Routers: IOS-XE/Firmware Upgrade (Install Mode)
04-06-2020 03:00 AM - edited 04-06-2020 03:10 AM
Please post the complete output to the following commands:
sh platform | b CPLD
sh version
sh boot
Can you also try the following command:
04-06-2020
04:33 AM
- last edited on
11-03-2022
10:34 PM
by
Translator
ERR-R02#sh platform | b CPLD
Slot CPLD Version Firmware Version
0 19060309 16.9(4r)
R0 19060309 16.9(4r)
F0 19060309 16.9(4r)
ERR-R02#sh version
Cisco IOS XE Software, Version 16.09.02
Cisco IOS Software [Fuji], ASR1000 Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 16.9.2, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Mon 05-Nov-18 19:31 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2018 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
ERR-R02 uptime is 10 weeks, 4 days, 22 hours, 3 minutes
Uptime for this control processor is 10 weeks, 4 days, 22 hours, 4 minutes
System returned to ROM by
Reload
Command
System restarted at 14:24:58 cet Wed Jan 22 2020
System image file is
bootflash:/asr1001x-universalk9.16.09.02.SPA.bin
Last reload reason:
Reload
Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Type: Permanent
License Level: adventerprise
Next reload license Level: adventerprise
The current throughput level is 25 kbps
Smart Licensing Status: Smart Licensing is DISABLED
cisco ASR1001-X (1NG) processor (revision 1NG) with 3853671K/6147K bytes of memory.
Processor board ID FXS2326Q0YZ
6 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
8388608K bytes of physical memory.
6594559K bytes of eUSB flash at bootflash:.
0K bytes of WebUI ODM Files at webui:.
ERR-R02#more bootflash:packages.conf | i SPA.pkg
ERR-R02#
%Error opening bootflash:packages.conf (Permission denied)
ERR-R02#more bootflash:/packages.conf
%Error opening bootflash:/packages.conf (Permission denied)
ERR-R02#sh bootflash: | i packages.conf
11 5899 Apr 01 2020 16:09:15.0000000000 +00:00 /bootflash/.installer/rollback/rb_points/0/packages.conf
ERR-R02#sh boot
BOOT variable does not exist
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
Standby not ready to show bootvar
Hope this helps.
04-06-2020 09:17 PM
I did these steps.
ERR-R02#more bootflash:packages.conf | i SPA.pkg boot rp 0 0 rp_boot asr1001x-rpboot.16.12.03.SPA.pkg iso rp 0 0 rp_base asr1001x-rpbase.16.12.03.SPA.pkg iso rp 0 1 rp_base asr1001x-rpbase.16.12.03.SPA.pkg iso rp 0 0 rp_daemons asr1001x-rpcontrol.16.12.03.SPA.pkg iso rp 0 1 rp_daemons asr1001x-rpcontrol.16.12.03.SPA.pkg iso rp 0 0 rp_iosd asr1001x-rpios-universalk9.16.12.03.SPA.pkg iso rp 0 1 rp_iosd asr1001x-rpios-universalk9.16.12.03.SPA.pkg iso rp 0 0 rp_security asr1001x-rpaccess.16.12.03.SPA.pkg iso rp 0 1 rp_security asr1001x-rpaccess.16.12.03.SPA.pkg iso rp 0 0 rp_webui asr1001x-webui.16.12.03.SPA.pkg iso rp 0 1 rp_webui asr1001x-webui.16.12.03.SPA.pkg iso rp 0 0 firmware_nim_ssd asr1001x-firmware_nim_ssd.16.12.03.SPA.pkg iso rp 0 1 firmware_nim_ssd asr1001x-firmware_nim_ssd.16.12.03.SPA.pkg iso rp 0 0 firmware_ngwic_t1e1 asr1001x-firmware_ngwic_t1e1.16.12.03.SPA.pkg iso rp 0 1 firmware_ngwic_t1e1 asr1001x-firmware_ngwic_t1e1.16.12.03.SPA.pkg boot rp 1 0 rp_boot asr1001x-rpboot.16.12.03.SPA.pkg iso rp 1 0 rp_base asr1001x-rpbase.16.12.03.SPA.pkg iso rp 1 1 rp_base asr1001x-rpbase.16.12.03.SPA.pkg iso rp 1 0 rp_daemons asr1001x-rpcontrol.16.12.03.SPA.pkg iso rp 1 1 rp_daemons asr1001x-rpcontrol.16.12.03.SPA.pkg iso rp 1 0 rp_iosd asr1001x-rpios-universalk9.16.12.03.SPA.pkg iso rp 1 1 rp_iosd asr1001x-rpios-universalk9.16.12.03.SPA.pkg iso rp 1 0 rp_security asr1001x-rpaccess.16.12.03.SPA.pkg iso rp 1 1 rp_security asr1001x-rpaccess.16.12.03.SPA.pkg iso rp 1 0 rp_webui asr1001x-webui.16.12.03.SPA.pkg iso rp 1 1 rp_webui asr1001x-webui.16.12.03.SPA.pkg iso rp 1 0 firmware_nim_ssd asr1001x-firmware_nim_ssd.16.12.03.SPA.pkg iso rp 1 1 firmware_nim_ssd asr1001x-firmware_nim_ssd.16.12.03.SPA.pkg iso rp 1 0 firmware_ngwic_t1e1 asr1001x-firmware_ngwic_t1e1.16.12.03.SPA.pkg iso rp 1 1 firmware_ngwic_t1e1 asr1001x-firmware_ngwic_t1e1.16.12.03.SPA.pkg iso fp 0 0 fp asr1001x-espbase.16.12.03.SPA.pkg iso fp 1 0 fp asr1001x-espbase.16.12.03.SPA.pkg iso cc 0 0 cc asr1001x-sipbase.16.12.03.SPA.pkg iso cc 0 0 cc_spa asr1001x-sipspa.16.12.03.SPA.pkg iso cc 0 1 cc_spa asr1001x-sipspa.16.12.03.SPA.pkg iso cc 0 2 cc_spa asr1001x-sipspa.16.12.03.SPA.pkg iso cc 0 3 cc_spa asr1001x-sipspa.16.12.03.SPA.pkg ERR-R02#sh boot BOOT variable = bootflash:packages.conf,1; CONFIG_FILE variable does not exist BOOTLDR variable does not exist Configuration register is 0x2102 Standby not ready to show bootvar
04-06-2020 10:27 PM - edited 04-06-2020 10:27 PM
Everything looks good.
The only thing to do is reboot the router.
04-07-2020 12:44 AM
04-07-2020 12:52 AM
