ASR1006 ASR1000-RP2 Unknown state after CPLD upgrade
ez9
I tried to upgrade the CPLD version on one ASR1000-RP2 card. The upgrade is finished ok and the cli prompts for a power cycle. I check with the command (show upgrade hw-programmable progress) and I proceeded to a power cycle but the RP is not powering anymore. All leds are switched off (including power led). I tried to boot the chassis using another RP and execute some commands:
#show diag slot R1 eeprom detail
Slot R1 EEPROM data is not initialized
#show inventory
 NAME: "module R1", DESCR: "Cisco ASR1000 Unknown Route Processor"
PID: ASR1000-RP-UNKNOWN, VID: , SN:
#show platform
Slot Type State Insert time (ago)
R1             unknown      00:07:26
Do you have any suggestions for this issue?
18 Replies 18
@ez9 wrote:
Is there anything else that I can try?
Check the used market for any available router or parts.
Thanks for the support. Is there any way (like debug mode) to detect the issue? eg damaged RAM module etc?
Only TAC will know how to.
 -     You may scrutinize output from show tech-support , but I am not optimistic.
 M.
