ASR903 boot IOS from USB in rommon mode
I've been given an ASR903 to configure for use on a testbed. However when I first booted it up, it says:
no valid BOOT image found
Final autoboot attempt from default boot device....
Warning: filesystem is not clean
Located tracelogs.332
Image size 0 inode num 12, bks cnt 0 blk size 8*512
Boot image size = 0 (0x0) bytes
Located ASR-903_FOX1729P00T.lic
Image size 1139 inode num 13, bks cnt 1 blk size 8*512
Boot image size = 1139 (0x473) bytes
Unknown image structure
boot: cannot determine first file name on device "bootflash:/"
autoboot: boot failed, restarting
Then the system starts up in ROMmon mode. I did some googling and tried to boot off of a usb which is the following:
rommon 14 > boot usb0:asr900rsp2-universalk9_npe.03.18.01.S.156-2.S1-std.bin
Checking USB devices..
USB EHCI 1.00
scanning USB bus for devices..
2 USB device(s) found
      Scanning bus for storage devices...
USB mass storage device detected
1 storage device(s) found
Located asr900rsp2-universalk9_npe.03.18.01.S.156-2.S1-std.bin, start cluster is 3
Image loaded
Boot image size = 312800260 (0x12a4f404) bytes
boot: error executing "boot usb0:asr900rsp2-universalk9_npe.03.18.01.S.156-2.S1-std.bin"
I've been googling different ways to upload the IOS onto the device all day and I'm at my wit's end. Any help is much appreciated.
Also I obtained the .bin file from another testbed ASR903 in a building that I don't have 24/7 access to.
Adam
16 Replies 16
assenga
I have the same Problem
Experts kindly help
Experts kindly help
Create a new thread and explain exactly what the issue is.
