05-09-2007 12:34 AM - edited 03-03-2019 04:53 PM
hi
often when u type an unknown command in a cisco router you get the message
Translating "cisco"....domain server 255.255.255.255
the error message appears 4 times before you are taken back to the console.
this is irritating,and i was wondering if there is a way to stop the router from displaying the error message
Solved! Go to Solution.
05-09-2007 12:38 AM
Hi Friend,
Just issue this command "no ip domain-lookup" on global config mode and this will take care of this messages.
Ankur
*Pls rate all helpfull post
05-09-2007 12:38 AM
Hi Friend,
Ankur
05-09-2007 01:58 AM
yeah ANKUR is 100% right in what he has posted.
05-09-2007 02:14 AM
so what really causes the router to show the message,what is it trying to do.
05-09-2007 02:19 AM
the router is trying to do a DNS lookup on what you have typed in because it doesn't recognise what you have typed in as a command.
if you have "fat" fingers like me it really helps to use "no ip domain-lookup" :-)
Jon
05-09-2007
02:04 AM
- last edited on
11-24-2021
01:20 AM
by
rayinala
Dont forget to issue " wr mem " after issuing "no ip-domain look up" command. If router reboots this command will be gone without " wr mem ".
-amit singh
06-14-2024 06:45 PM
Hi Everyone,
I've been reading through the feedback posted by others, and I noticed many of us share similar experiences. As a student learning about Cisco Initial Configuration, I've encountered a recurring issue. When typing commands, especially as a beginner, it's easy to make mistakes, such as typing the wrong command or missing a character. Pressing enter starts a domain lookup, which can be frustrating.
Although I find this feature somewhat annoying, I believe it might have its uses, even if I'm not entirely sure what they are due to my limited experience. Instead of entirely disabling domain lookups, I suggest implementing a way to abort the translation process. In a Linux terminal, you can terminate a process by pressing CTRL+C. Similarly, in Cisco Packet Tracer, we can use the shortcut key Ctrl + Shift + 6 to stop the domain lookup process. Now, obviously, your query is not about the Cisco Packet Tracer; I believe it's about the Cisco Router Device. But I think this command is also usable in these Live Cisco Routers.
This solution seems practical and allows us to keep the domain lookup feature in case it's needed later. I realize my experience is limited compared to others, particularly the Cisco employees who have answered. However, I believe this compromise could be beneficial for many users.
In summary, instead of completely disabling the domain lookup, we could use the Ctrl + Shift + 6 shortcut to abort the process if an unintended command is entered. I hope this suggestion is helpful, and I appreciate any feedback or additional insights from more experienced users.
Let me know your thoughts on this.
Thank You!
