Bookmark
Subscribe
1381
ASR920 licensing
ronneh
I have an question about the licensing the cisco ASR-920-24SZ-M in a disconnected network (no internet).
I work for a company with disconnected networks. We have license managers who can login to the CSSM Cisco portal to get us the authorization codes
for the specific ASR920s.
The main problem is that it seems we cannot get the ASR920 licensed or get the right license IN USE.
We tried the following trough smart licensing:
router# show license reservation
License Reservation: DISABLED
router(config)# license smart enable
router(config)# license smart reservation
router(config)# do show license reservation
License Reservation: ENABLED
Overall Status:
Active: PID:ASR-920-24SZ-M ,SN:xxxxxxx
Reservation Status: Not Installed
Export-Controlled Functionality:  NOT ALLOWED
router# license smart reservation request local
Enter this request in the Cisco Smart Software Manager portal
UDI : PID:ASR-920-24SZ-M , SN:xxxxxxx
Request code: xxxxx:xxxxx
I provide my license manager with the request code and i got an Authorization + Serialnumber.txt back.
I upload this .txt to my ASR920 trough TFTP to the bootflash:
the router did complain about .txt being not a right file format but i accepted the file format.
and used the following command:
router# license smart reservation install file bootflash:authcodesnr.txt
Reservation install file succesful
Last Confirmation code UDI: PID:ASR-920-24SZ-M, SN,xxxxx
Confirmation code:xxxxx
After this ASR920 shows like 7 messages
AGENT_REG_SUCCESS
AUTH_RENEW_SUCCESS
RESERVED_INSTALLED
EXPORT_CONTROLLED
SLR_IN_COMPLIANCE 2x
IN_COMPLIANCE
Since I don't have that part written down / copied from the disconnected network i cannot post it here but i do have the most important results of show license all
router# show license all
Smart Licensing Status
Smart Licensing is ENABLED
License Reservation is ENABLED
Registration:
Status: REGISTERED - SPECIFIC LICENSE RESERVATION
Export-Controlled Functionality: ALLOWED
Initial Registration: SUCCEEDED on Oct 19 13:05:21 2022 UTC
License Authorization:
Status: NOT AUTHORIZED
Export Authorization Key:
Features Authorized:
<none>
Utility:
Status: DISABLED
Data Privacy:
Sending Hostname: yes
Callhome hostname privacy: DISABLED
Smart Licensing hostname privacy: DISABLED
Version privacy: DISABLED
Transport:
Type: Transport Off
Miscellaneous:
Custom Id: <empty>
License Usage
24portGE-4port10GE (24portGE-4port10GE):
Description: 24portGE-4port10GE
Count: 1
Version: 1.0
Export status: NOT RESTRICTED
Feature Name: 24portGE-4port10GE
Feature Description: 24portGE-4port10GE
Reservation:
Reservation status: NOT INSTALLED
ASR 920 METRO IP ACCESS (metroipaccess):
Description: ASR 920 METRO IP ACCESS
Count: 0
Status: NOT IN USE
Feature Name: ASR 920 METRO IP ACCESS
Feature Description: ASR 920 METRO IP ACCESS
Reservation:
Reservation status: SPECIFIC INSTALLED
Total reserved count: 1
Product Information
UDI: PID:ASR-920-24SZ-M,SN:xxxxx
Agent Version
Smart Agent for Licensing: 5.0.9_rel/68
Reservation Info
License reservation: ENABLED
Overall status:
Active: PID:ASR-920-24SZ-M,SN:xxxxx
Reservation status: SPECIFIC INSTALLED on Oct 19 12:40:38 2022 UTC
Last Confirmation code:xxxxx
Status:PAK
Specified license reservations:
Enforcement type: NOT ENFORCED
Term information:
Authorization type: SPECIFIC INSTALLED on Oct 19 12:40:38 2022 UTC
License type: PERPETUAL
Term Count: 1
What do I need to do to make it in-use?
I tried to set the right boot level as well:
router(config)#license boot level metroipaccess
after a reboot it looks likes its still not licensed.
Any help is appreciated
Gr
Ron
0 Replies 0
