01-27-2015 01:51 AM - edited 03-05-2019 12:39 AM
I am trying to integrate ASR920 into an existing MPLS network, but I am not able to change the MTU on the BDI interface. My IGP is OSPF and I want to avoid the usage of the "ip ospf mtu-ignore" command in the interface settings... Any ideas how to solve this issue?
asr920-test(config)#interface bdi 2344
asr920-test(config-if)#mtu 1998
% Interface BDI2344 does not support user settable mtu.
Peter
Solved! Go to Solution.
09-07-2015 03:45 PM
Hi Peter,
"MTU" configuration is not supported on BDI interface, it's a limitation. Only IP MTU configuration is allowed on BDI interfaces. You can try "ip mtu 1998".
Best Regards,
Bheem
09-07-2015 03:45 PM
Hi Peter,
Best Regards,
Bheem
09-07-2015 04:18 PM
I try with "ip mtu", but I got no results
the version IOS:
Cisco IOS XE Software, Version 03.15.01.S - Standard Support Release
Cisco IOS Software, ASR920 Software (PPC_LINUX_IOSD-UNIVERSALK9_NPE-M), Version 15.5(2)S1, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Thu 25-Jun-15 03:15 by mcpre
09-08-2015 12:02 AM
Hi Roberto,
if you change the ip mtu, you have to use the "show ip interface" command
On IOS platforms the ip mtu can be equal or less as mtu of physical interface, on IOS XE platforms you do not have this limit because the physical interface usually supports greater mtu than 1500B.
P.
09-08-2015 08:11 AM
the problem persists, "ip mtu" command
Router#SH RUN int bdi 50
Building configuration...
Current configuration : 75 bytes
interface BDI50
ip address 20.20.20.1 255.255.255.252
ip mtu 1600
end
Router#ping 20.20.20.2 si
Router#ping 20.20.20.2 size 1501 df
Sending 5, 1501-byte ICMP Echos to 20.20.20.2, timeout is 2 seconds:
Packet sent with the DF bit set
Success rate is 0 percent (0/5)
Router#ping 20.20.20.2 size 1500 df
Sending 5, 1500-byte ICMP Echos to 20.20.20.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
Router#sh int bdi 50 | i MTU
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Router#
09-08-2015 08:20 AM
Hi Peter,
what is the mtu configured on 20.20.20.2?
What is the configuration of the underlying layer 2 port which is configured for bridge domain 50? Have you increased the MTU there?
Also please do "sh ip int bdi 50 | i MTU" not "sh int bdi 50 | i MTU".
Best Regards,
Bheem
09-11-2015 06:52 AM
here is my partial configuration, you need also to increase the mtu on a physical interface
interface BDI20
ip mtu 1512
interface GigabitEthernet0/0/4
mtu 1512
no ip address
media-type auto-select
negotiation auto
service instance 10 ethernet
encapsulation untagged
bridge-domain 20
R2#ping 192.168.1.10 size 1512 df
Sending 5, 1512-byte ICMP Echos to 192.168.1.10, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
