SIP Door release system and CME 9.5
Nick Cutting
The Door release is a
Zenitel IPSTATION v2.0 ( on the web page it is called a Turbine IP-stationWeb)
All teh documentation is for a call manager, not a call manager express.
I cannot get the door bell button to ring the reception, the button does nothing.
I am sure the Zenitel IPSTATION v2.0 is configureed correctly
here is the confog on the CME:
voice register dn  40
number 4040
voice register pool  8
id mac 0013.CB06.1FF7
number 1 dn 40
dtmf-relay rtp-nte
username 4040 password 4040
Here is the Show output, as you can see it is registered.
sh voice register pool 8
Pool Tag 8
Config:
  Mac address is 0013.CB06.1FF7
  Number list 1 : DN 40
  Proxy Ip address is 0.0.0.0
  Current Phone load version is Zenitel IPSTATION v2.0
  DTMF Relay is disabled
Call Waiting is enabled
  DnD is disabled
  Video is disabled
  Camera is disabled
  Busy trigger per button value is 0
  keep-conference is enabled
  registration expires timer max is 3600 and min is 1800
  Lpcor Type is none
  Transport type is udp
  service-control mechanism is not supported
  registration Call ID is 1544401931@10.42.31.10
  Registration method: per line
  Privacy feature is not configured.
  Privacy button is disabled
  active primary line is: 4040
  contact IP address: 10.42.31.10 port 5060
  conference admin: no
  conference add mode: all
  conference drop mode: never
  paging-dn: config 0 [multicast]  effective 0 [multicast]
Dialpeers created:
Dial-peers for Pool 8:
dial-peer voice 40013 voip
destination-pattern 4040$
session target ipv4:10.42.31.10:5060
session protocol sipv2
  after-hours-exempt   FALSE
Statistics:
  Active registrations  : 1
  Total SIP phones registered: 19
  Total Registration Statistics
    Registration requests  : 349
    Registration success   : 349
    Registration failed    : 0
    unRegister requests    : 348
    unRegister success     : 348
    unRegister failed      : 0
    Attempts to register
           after last unregister : 0
    Last register request time   : 08:00:39.549 GMT Tue Dec 24 2013
    Last unregister request time : 08:05:43.406 GMT Tue Dec 24 2013
    Register success time        : 08:00:39.549 GMT Tue Dec 24 2013
    Unregister success time      : 08:05:43.406 GMT Tue Dec 24 2013
The when I call the intercom - it beeps Just once.
Also when pressing the botton on the front - it is set to Dial reception on 6800, but the phone never rings.
Does anyone know of some good debugs to troubleshoot this - or has worked with these two pieces of hardware before?
anderson_tjrj
you managed to successfully register the Zenitel IPSTATION v2.0?
At the exit of their concert shows: Current Phone load version is Zenitel IPSTATION v2.0 where you downloaded this "Zenitel IPSTATION v2.0" file.
I have a CME version 10.0 and I have a similar problem but could not even register the device.
You can send me the output of the show voice register global?
