Assistance with automatic fail-over route
ssuttle1
I need some assistance configuring an automatic failover/backup route.  My network has a primary ISP that connects to an ASA at one location and a backup ISP that connects to another ASA at a different location.  Currently, if our primary ISP link goes down we have to manually change a static route on two layer-3 core switches to point to the secondary ASA/ISP.  I would like to configure it to failover to the secondary automatically and failback when the primary comes back up.  Any guidance is appreciated.
7 Replies 7
have a look at the document below:
Configure the ASA for Redundant or Backup ISP Links
https://www.cisco.com/c/en/us/support/docs/security/asa-5500-x-series-next-generation-firewalls/118962-configure-asa-00.html
Cristian Matei
   If you want a functional solution and not just some opinions, attach a diagram, even hand made and picture it, specifying the layer 3 devices (edge/core), the IP interconnects, what kind of static/dynamic routing you run where (internal routing in your network and external routing towards your ISP).
Cristian Matei.
Here's a diagram of the edge.  I have multiple LANs behind both multilayer switches.  To manually failover/back I SSH into each C3650 and change the static route. (ip route 0.0.0.0 0.0.0.0 LIBASA (primary ISP Connection)) (ip route 0.0.0.0 0.0.0.0 PD-ASA (backup ISP connection)).
   Is dynamic routing between your switches and ASA's an option? Do you run any routing protocol currently?
Cristian Matei.
Currently, we have a mix of Static routes and EIGRP.
     You could run EIGRP up to the two ASA's; on the ASA's sun EIGRP only on the inside interface. Configure default route on both ASA's, with tracking (in order to be redistributed via EIGRP only if the next-hop is reachable), and redistribute the default route into EIGRP on both ASA's, with a better metric from the ASA that you want to be preferred for Internet exit.
sla monitor 100
 type echo protocol ipIcmpEcho 2.2.2.254 interface outside
 num-packets 3
 frequency 10
sla monitor schedule 100 life forever start-time now
track 1 rtr 100 reachability
route outside 0.0.0.0 0.0.0.0 203.0.113.2 1 track 1
prefix-list DEFAULT_ROUTE permit 0.0.0.0/0
route-map DEFAULT_ROUTE permit 10
 match ip address prefix DEFAULT_ROUTE
 set metric xx xx xx xx xx
router eigrp 100
 redistribute static route-map DEFAULT_ROUTE
Cristian Matei.
