Routing ASA to ISR to Switch
Senbonzakura
Current ASA configuration is working for Internet for 192.168.10.0 network but I want the others to work as well.
So what I want to do next is feed the Firewall to the ISR which is then feeding my switch.
On my Firewall on E0/2 I have 192.168.200.1 255.255.255.252 configured.
On my Router Interface G0/1 that is connected to the Firewall I have 192.168.200.2 255.255.255.252
On my Router Interface G0/0.1 that is connected to my switch I have 192.168.80.1 255.255.255.0 (Encap DOTQ1 200 (For VLAN 200)
Then on my Switch that's feeding the Router I have:
Switchport mode trunk
Switchport trunk allowed vlan 200
no shut
VLAN 200 has an IP of 192.168.80.2 255.255.255.0 on the switch which is port G1/0/40
Port: G1/0/39 is configured as an access of course.
How would I get the internet through the firewall to the switches VLAN statically? Not sure what the routing table should be for the firewall and the ISR to Switch
Below is ASA Configuration
ASA Version 8.2(5)59
hostname ASA
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
interface Ethernet0/0
description WAN
nameif outside
security-level 0
ip address dhcp setroute
interface Ethernet0/1
description LAN
nameif inside
security-level 100
ip address 192.168.50.1 255.255.255.0
interface Ethernet0/2
description ISR
nameif inside-ISR
security-level 100
ip address 192.168.200.1 255.255.255.252
interface Ethernet0/3
shutdown
no nameif
no security-level
no ip address
interface Management0/0
description ASDM GUI
nameif management
security-level 100
ip address 192.168.100.2 255.255.255.0
management-only
ftp mode passive
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object-group network inside-subnet
object-group network obj_ISR
object-group network management_any
pager lines 24
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu inside-ISR 1500
mtu management 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
route inside-ISR 192.168.200.0 255.255.255.0 10.0.0.1 1
route inside-ISR 192.168.200.0 255.255.255.0 192.168.200.2 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.100.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.50.10-192.168.50.254 inside
dhcpd dns 75.75.75.75 75.75.76.76 interface inside
dhcpd enable inside
dhcpd address 192.168.100.10-192.168.100.254 management
dhcpd dns 75.75.75.75 75.75.76.76 interface management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
service-policy global_policy global
prompt hostname context
Cryptochecksum:77cfb5a40d21d93057330e405e354625
: end
Below is Routers configuration
Current configuration : 1291 bytes
! Last configuration change at 20:19:14 UTC Thu Apr 2 2020
version 15.7
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 25
ip cef
no ipv6 cef
license udi pid CISCO1921/K9 sn FTX18508441
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.1
encapsulation dot1Q 200
ip address 192.168.80.1 255.255.255.0
interface GigabitEthernet0/1
description ISR-ASA
ip address 192.168.200.2 255.255.255.252
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.200.1
ip route 192.168.80.0 255.255.255.0 192.168.200.0
ip route 192.168.80.0 255.255.255.0 192.168.200.1
control-plane
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
login
transport input none
scheduler allocate 20000 1000
end
If you did not have the ISR router it would be possible to connect the switch directly to the ASA. If the switch has just a single vlan it would make sense to connect an access port on the switch (a port in that vlan) to the ASA interface. If you connect this way you would change the IP address configured on the ASA interface from 192.168.200.1 to 192.168.80.1 with the /24 mask. You would configure a DHCP pool for that network. And you would remove the static route to that network
route Inside-ISR 192.168.80.0 255.255.255.0 192.168.200.2 1
You would need to create an object for network 192.168.80.0 and would need to configure a nat for it.
But I see that the current router to switch connection is a trunk which suggests that the switch has multiple vlans. If you want to connect the switch to ASA using a trunk that can be done. You would change the ASA interface configuration to indicate that it is connected to a trunk and would identify the appropriate vlan and the ASA would process the dot1Q encapsulation. You would still do the other things that I described (remove the static route, create the object and configure the nat.
You also ask about configuring network objects. Sometimes it is convenient to configure a network object that has multiple networks in it. Other times it is convenient to configure a network object with just a single network in it.
Looking through the configs I have these comments and suggestions
- you have this static route on the router
That network is a connected network so you do not need a static route for it. And I do not understand why you put the ASA as the next hop to reach that network. You should remove this static route.
- the ASA has an object and a nat for the 192.168.200.0 network
object network obj_isr
nat (Inside-ISR,outside) dynamic interface
I do not know why you are doing a translate for this network. This network is just a transit connection between the ASA and the router. Why would anything with a source address in 192.168.200.0 be going to the Internet? I dont think this huts anything, but I dont see it as helping anything.
- the ASA does not have an object and does not have a nat for the 192.168.80.0 network. You need to configure these. This is the main reason that network can not get to the Internet.
Rick
9 Replies 9
Abzal
Level 7
Level 7
On ASA you will need to configure static route back to your LAN subnet like this:
route inside-ISR 192.168.80.0 255.255.255.0 192.168.200.2
If your firewall connected to ISP providing you the Internet then configure PAT on ASA and ACL:
nat (inside-ISR) 1 192.168.80.0 255.255.255.0
global (outside) 1 interface
access-list acl_out permit ip any any
access-group acl_out in interface outside
Best regards,
Abzal
Richard Burts
There are several issues to be addressed. I see these static routes on the ASA
Since 192.168.200.0 is on a connected interface you do not need either of these static routes. And I am very puzzled at the first one which specifies a next hop of 10.0.0.1. Where is that address supposed to be?
I do not see any static route for the network you want to reach inside 192.168.80.0. That needs to be added.
I do not see any address translation configured on the ASA (not for the original inside subnet and not for the new subnet). You need to add address translation to the configuration of the ASA.
Your description of the environment says that the inside network is 192.168.10.0 but the configuration says that it is 192.168.50.0.
On the router I see these static routes
Since 192.168.80.0 is a connected subnet you do not need either of those static routes. And the first static route specified an invalid next hop. Both of these static routes should be removed.
Rick
Yeah, it got messy so I cleared the configuration and pretty much just did it over again.
The 10.0.0.1 is from the ISP. The E0/0 is set to be assigned from the modem which is doing DHCP I believe thats why I have ip address dhcp setroute configured on it. I removed all of those routes that you mentioned because they didn't make any sense as you mentioned.
Based on the current addresses for the interfaces, what Routes should I have in place for the hops?
I'm not sure how to configure the address translation for the other networks.
Also, do I even need to add a route to the outside or does the address translation automatically do that?
192.168.200.1 - .2 255.255.255.252 is for the connection between the ASA and ISR then 192.168.80.0 network is for the VLAN on the switch.
If you assign e0/0 a static from ISP then they shoud've provided you a default gateway to go outside world for example 10.0.0.2.
Let's say default gateway is 10.0.0.2 and e0/0 IP is 10.0.0.1 then ip route would look like this:
route outside 0.0.0.0 0.0.0.0 10.0.0.2 1
This would your default route from ASA to the Internet.
Because your 192.168.80.0/24 is behind router you'll need static route for that too:
route inside-ISR 192.168.80.0 255.255.255.0 192.168.200.2 1
192.168.80.0/24 is directly subnet to your router so no static route is needed.
Regarding NAT you can either NAT everything to outside interface coming from the router or put an ACL:
nat (inside-ISR) 1 0.0.0.0 0.0.0.0
access-list LAN ext permit ip 192.168.80.0 255.255.255.0 any
nat (inside-ISR) 1 access-list LAN
Best regards,
Abzal
Thank you for clarifying that 10.0.0.1 is the address of the ISP. Since you are using this configuration
it takes care of the address on the interface and also takes care of the default route so you do not need to configure a default route. The address translation does not take care of this. You would need to configure a static route on the ASA for the 192.168.80.0 network which is reached via the router. That would be the only route you need to configure on the ASA. On the router you would want a static default route with the ASA as the next hop.
Rick
Okay, thank you so much for your help :) Now only one last few questions then we will be all set.
If I wasn't an ISR, how else would I configure to route VLAN traffic from my switches after it's been configured on the switch? What would the process and commands be?
Also, when I configure the command below. Do all the networks need to be under the same network object or does each network have its own network object?
network object (anyname)
subnet 192.168.50.0 255.255.255.0
nat (inside,outside) dynamic interface
ISR Configuration
Building configuration...
Current configuration : 1345 bytes
! Last configuration change at 23:38:38 UTC Fri Apr 3 2020
version 15.7
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip dhcp pool MYPOOL1
network 192.168.80.0 255.255.255.0
default-router 192.168.80.1
dns-server 75.75.75.75 75.75.76.76
ip cef
no ipv6 cef
redundancy
no ip address
shutdown
duplex auto
speed auto
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.1
encapsulation dot1Q 80
no ip http server
control-plane
line con 0
line aux 0
line 2
no exec
stopbits 1
line vty 0 4
login
end
ASA Configuration
ASA# show run
: Saved
: Serial Number: JMX0949K0DM
: Hardware: ASA5510, 1024 MB RAM, CPU Pentium 4 Celeron 1600 MHz
ASA Version 9.1(7)32
hostname ASA
domain-name www.domain.com
names
description WAN
nameif outside
security-level 0
description Inside-Ruckus
nameif Inside-Ruckus
security-level 100
description ISR
nameif Inside-ISR
security-level 100
shutdown
no nameif
no security-level
no ip address
nameif management
security-level 0
ip address 192.168.100.1 255.255.255.0
ftp mode passive
dns server-group DefaultDNS
object network inside-subnet
subnet 192.168.200.0 255.255.255.252
pager lines 24
mtu outside 1500
mtu Inside-Ruckus 1500
mtu management 1500
mtu Inside-ISR 1500
arp timeout 14400
no arp permit-nonconnected
nat (Inside-Ruckus,outside) dynamic interface
timeout pat-xlate 0:00:30
user-identity default-domain LOCAL
http server enable
http 192.168.100.2 255.255.255.255 management
no service password-recovery
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpool policy
telnet timeout 5
ssh stricthostkeycheck
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
dhcpd address 192.168.50.10-192.168.50.254 Inside-Ruckus
dhcpd dns 75.75.75.75 75.75.76.76 interface Inside-Ruckus
dhcpd enable Inside-Ruckus
policy-map type inspect dns migrated_dns_map_1
parameters
inspect ftp
inspect h323 h225
inspect h323 ras
inspect ip-options
inspect netbios
inspect rsh
inspect rtsp
inspect skinny
inspect esmtp
inspect sqlnet
inspect sunrpc
inspect tftp
inspect sip
inspect xdmcp
no call-home reporting anonymous
call-home
profile CiscoTAC-1
no active
destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
destination address email callhome@cisco.com
destination transport-method http
subscribe-to-alert-group diagnostic
subscribe-to-alert-group environment
subscribe-to-alert-group inventory periodic monthly
subscribe-to-alert-group configuration periodic monthly
subscribe-to-alert-group telemetry periodic daily
Cryptochecksum:d2d0a835adbef41de0882854d761d1c2
: end
I'm getting internet only out of my E0/1 port but not the switch thats connected to the ISR. I believe I went through and fixed it all. Take a look at it and tell me if there is anything else that I need to add?
Rick
Thank you for everything, it works perfectly. Now, the reason why I'm using the ISR is for learning purposes and I'm trying something newer like running HSRP and configuring two ISR's for redundancy after the firewall just to try something new.
Now I'll mark yours as the resolution, just have one more question. What would be the process/commands for configuring the ports on the ASA if I was to connect them to a switch for making it a trunk port and allowing VLAN traffic like I would on the ISR? I haven't learned that yet but that would help me :) Thank you once again.
