ATM Card
Caue W
Question... the card NM-1T3/E3 supports all the same features that a NM-1A-E3 card does?!
I ask this because a customer has ordered the wrong one, and now we're kind of having problems to get a new one (the correct). Is there any document that I can look to find a way to translate the config to meet the NM-1T3/E3 card needs?!
Thanks!
paolo bevilacqua
Actually these are very different cards so that many commands are different. However if the circuit is working, most of the time the defaults will work ok and you just need to configure the IP address.
Key Features are Supported by NM-1A-E3 -
• ATM Classes of Service support for: Unspecified Bit Rate (UBR), UBR+, Variable Bit Rate real-time (VBR-rt), Variable Bit Rate non-real time (VBR-nrt), Constant Bit Rate (CBR), and Available Bit Rate (ABR)
• ATM UNI 3.0, 4.0 Traffic Management support
• RFC 1483 and RFC 1577 support
• 1024 maximum simultaneous Virtual Connections (VCs)
• 8 bits of VPI (VPI range 0-256), 10 bits of VCI (VCI range 0-1024)
• Permanent Virtual Circuits (PVCs) and Switched Virtual Circuits (SVCs)
• PLCP and HEC cell delineation support
• Operations and Management (F5 OAM) cell support
• LANE 2.0 support
• ILMI 1.0 support
• IETF PPP over ATM support
• IP-to-ATM Class-of-Service (CoS) Mapping Feature
• Multiprotocol Label Swapping (MPLS) VPN support
• MPOA Client and Server
• Next Hop Routing Protocol (NHRP)
• On-line Insertion and Removal (OIR) on 3660
• Permanent Virtual Path (PVPs) support
• FRF.5/8 Interworking
• ITU-T G.703 Compliant
Features supported by NM-1T3/E3 -
DS3/E3 Specifications
• DSX3 level interface with dual female 75-ohm BNC coaxial connectors per port (separate RX and TX)
• Full- and half-duplex connectivity at DS3 rate (44.736 MHz)
• Full- and half-duplex connectivity at E3 rate (34.368 MHz)
• Scrambling and subrate support of major DSU vendors
• Line build-out-Programmable for up to 450 feet of 734A or equivalent coaxial cable or up to 225 feet for 728A or equivalent coaxial cable
• C-bit, or M23 framing for T3, bypass and G.751 framing for E3 (software selectable)
• Binary 3-zero substitution (B3ZS) (T3) or high-density bipolar with three zeros (HDB3) (E3) line coding
• Support for 16- and 32-bit CRC (16-bit default)
• DS3 FEAC channel support
• Twenty-four-hour history maintained for error statistics and failure counts
• DS3 alarm and event detection (once per second polling)
• Alarm indication signal (AIS)
• Out of frame (OOF)
• Line code violation (LCV)
• Excessive zeros (EXZ)
• Far-end receive failure (FERF)
Serial Encapsulations
• HDLC
• PPP
• Frame Relay
• ATM Data Exchange Interface (ATM-DXI)
-> Sushil
