ATM Configration
ralwarrag
Hello ,,
I have 7200 VXR router and I need to configure on it ATM connection , and it's my first time to configure it ,so can you people help me on it and I have some question like what I need to get from the data provider ?? and what is the syntax of the configuration to accomplish it ??
Many thanks
jackyoung
Level 6
Level 6
First of all, you have to check what ATM service will the PTT support.
Check below link for the IP over ATM and select the left hand side menu for other ATM services.
http://www.cisco.com/en/US/tech/tk39/tk371/tsd_technology_support_protocol_home.html
The PTT should tell you the required information for configuration. If you consider it is not sufficient, you can based on the sample config to ask them to fill what value to the those config.
Hope this helps.
