cisco 2610
rehan_uet
Does cisco 2610 support NM-2FE2W module.
sachinraja
Level 9
Level 9
Hello rehan
The 2610 does not support the NM-2FE-2W module. you need to have the 2691 or the other higher end routers to support this card. You can confirm this from the following URLs:
http://cisco.com/en/US/products/hw/routers/ps259/products_data_sheet09186a00801aa71c.html
http://cisco.com/en/US/products/hw/routers/ps259/products_data_sheet0900aecd800fa5be.html
Hope this helps. all the best. rate replies if found useful..
Raj
