ATM problem with various models
ronald.tuns
Hi everyone,
I'm having a problem with various Cisco ADSL modems and one specific ISP. The ISP is changing their ATM network to Ethernet and ever since the Cisco routers regularly lose their connection. Only resetting the modem brings the line back. According to the ISP this is a known problem with Cisco modems and they have sent an example config to configure the ATM.
We have implemented this config, but the problem is still there. Since the problem does not occur with modems from other brands (Alcatel and even Linksys!) the ISP lays the responsibility with us, being the supplier of the modem.
According to the ISP oam PVC managed causes the problem, only this is already disabled in our configs.
I have enabled ATM debugging on one router (887 ISR) and this error occurs repeatedly:
cisco ATM_UCC_GetChannelHandler_PQ2CE: wrong ChannelCode
Any idea what this could mean ?
Thanks for any help !
Ronald Tuns
25 Replies 25
Frederic Vanderbecq
Hello Ronald,
looking to the error, it could be linked to the following bug:
CSCtl72890 duplicate of CSCtq05004    Dialer loses IP Address sporadically
CSCtq05004 is currently not fixed. Though, with the description above, it is not enough to say for sure this is the issue you are facing.
As this may be complex to resolve via the forum, it might be best to raise a TAC case for this issue.
Things that could be interesting to log at the time of the problem is:
     - debug atm error
     - debug atm event
     ((the above debugs could be enabled prior to the problem appearance and their logs checked at the time of the probmem))
     - show atm pvc /   a few times in a row
     - show dsl int atm ...     or     show controller dsl ...
At the moment, what is the configuration used on the CPE ? Maybe the configuration could shed additional light to this matter.
paolo bevilacqua
You need to update ADSL firmware. That unfortunately requires a support contract for download from cisco.com.
Hi everyone,
Thanks for your replies.
Most models have the latest IOS version, which should include the lastest ADSL firmware ?
Furthermore, I have found that if I downgrade a 877 ISR to IOS version 12.3-8.YI2 the connection is stable. Suffice to say I want to use at least 12.4 so I am affraid that this is going to be a trial-and-error to find the right IOS version ?
I haven't tried a different IOS on The 800 series ISRs yet.
I am considering opening a TAC case, since it is definitely IOS related.
Ronald
Latest IOS what ?
You need to check "show dls interface".
If the ADSL FW is behaving with you particular line and DSLAM, then you have a stable connection is stable. Otherwise, you do not.
That is mostly indipendent from IOS.
If you're having the same problem as me, which it appears it's possible that you may be, then you want to steer clear of the "latest" IOS.
I've found this on the 15.0.x branch. Specifically, the issue arrives in early 2011 with 15.0(1)M5. According to my testing, 15.0(1)M4 is the last good release, which was built November 2010.
I guess it's possible that this years' 12.4 releases have had this code merged into them too.
Although our circumstances are all quite different, to me this all points back to one thing: Broken ATM code. But surely it's not possible that Cisco would produce fundamentally broken releases for 6 months?
Here's a potentialy related issue from another user, with some commentary on my scenario:
https://supportforums.cisco.com/thread/2092730
Hi Matthew,
Thanks for your input! I am baffled too.
This problem is haunting me on more and more connections, all which worked fine until the ISP adjusted their ATM signal because of their migration.
Try to explain to your customers that a 30 dollar low-end router delivers a perfect stable line and the router they bought at 10 times that price can't do that...
I tried various 15.x releases all with the same error and the only 12.4.x that is stable, stalls the download to all but a stop.
That is why I have opened a TAC to see what comes up, so far it's a trial-and-error process though.
I'll keep you posted on my findings...
If you want help from this forum, post config, and "show dsl interface".
I'm not entirely sure if me posting 1000 lines of config to this thread is going to add an awful lot of value to this discussion at present. But OK, here's some of it:
Router#show version
Cisco IOS Software, C870 Software (C870-ADVIPSERVICESK9-M), Version 15.0(1)M4, RELEASE SOFTWARE (fc1)
Router#show dsl interface atm0
ATM0
Alcatel 20190 chipset information
                ATU-R (DS)                      ATU-C (US)
Modem Status:    Showtime (DMTDSL_SHOWTIME)
DSL Mode:        ITU G.992.5 (ADSL2+) Annex M
ITU STD NUM:     0x03                            0x2
Chip Vendor ID:  'STMI'                          'BDCM'
Chip Vendor Specific:  0x0000                    0x918F
Chip Vendor Country:   0x0F                      0xB5
Modem Vendor ID: 'CSCO'                          '    '
Modem Vendor Specific: 0x0000                    0x0000
Modem Vendor Country:  0xB5                      0x00
Serial Number Near:    FCZ1426C2HW
Serial Number Far:
Modem VerChip ID:        C196 (3) capability-enabled
DFE BOM:         DFE3.0 Annex M (3)
Capacity Used:   97%                             99%
Noise Margin:     5.5 dB                          6.0 dB
Output Power:    19.0 dBm                        12.5 dBm
Attenuation:     41.0 dB                         23.0 dB
FEC ES Errors:   87                               0
ES Errors:       10                              10
SES Errors:       8                               0
LOSES Errors:     8                               0
UES Errors:       0                              289
Defect Status:   None                            None
Last Fail Code:  None
Watchdog Counter: 0x1E
Watchdog Resets: 0
Selftest Result: 0x00
Subfunction:     0x00
Interrupts:      4152 (0 spurious)
PHY Access Err:  0
Activations:     1
LED Status:      ON
LED On Time:     100
LED Off Time:    100
Init FW:         init_AMR-4.0.017_no_bist.bin
Operation FW:    AMR-4.0.017.bin
FW Source:       external
FW Version:      4.0.17
                 DS Channel1      DS Channel0   US Channel1       US Channel0
Speed (kbps):             0             10847            0              2048
Cells:                    0         29305350             0         553592904
Reed-Solomon EC:          0            12049             0                 0
CRC Errors:               0              445             0                13
Header Errors:            0              434             0                77
Total BER:                0E-0           6703E-10
Leakage Average BER:      0E-0           3957E-9
Interleave Delay:         0               24             0                58
Bitswap:               enabled            enabled
Bitswap success:          0                   0
Bitswap failure:          0                   0
LOM Monitoring : Disabled
DMT Bits Per Bin
000: 0 0 0 0 0 0 0 7 9 A B B C C D C
010: D D D D D D D D D D D D D D D D
020: C B A A A A A 9 9 9 9 9 9 9 9 8
030: 8 8 8 8 8 7 7 7 0 0 0 0 A B C C
040: C C C D D D D D D D D C D D D D
050: D C C C D C D C C C C C C C 2 C
060: C C C C C C C C C C C C C C D C
070: C C C C C C C B B B B B B B B C
080: B 7 8 B B B B B B B B B B B B B
090: B B B B B B B B B B B A B B B B
0A0: A A A B B A B 6 A A A A A A A A
0B0: A A A A A A A A A A A A A A A B
0C0: A A 9 A A A A A 9 9 A A A A A A
0D0: A 9 8 5 9 9 A A A A A 9 9 9 9 9
0E0: 8 4 5 8 9 9 9 9 9 9 9 9 9 9 9 9
0F0: 2 8 9 9 7 9 9 9 9 9 8 8 7 6 6 9
100: 8 8 9 9 9 9 9 8 9 8 9 8 9 9 8 9
110: 8 8 8 9 8 8 8 8 8 7 5 8 8 8 8 8
120: 8 7 8 8 8 8 7 8 8 8 8 8 8 8 7 7
130: 7 7 7 6 7 7 7 7 7 7 7 7 7 7 6 0
140: 5 6 6 6 6 5 5 5 5 5 0 5 5 5 0 5
150: 5 3 0 4 0 5 5 5 5 5 5 5 5 5 5 5
160: 4 4 5 4 4 0 4 0 4 0 4 4 4 4 4 4
170: 3 0 0 3 3 3 3 3 2 3 2 2 3 2 2 2
180: 2 1 2 2 2 2 2 2 2 2 2 2 2 2 2 2
190: 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2
1A0: 2 2 2 2 0 2 0 1 1 1 1 1 1 1 1 1
1B0: 1 0 1 1 0 1 0 0 0 0 0 0 0 0 0 0
1C0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1D0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1E0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
DSL: Training log buffer capability is not enabled
And some relative snips of config:
interface ATM0
no ip address
no atm ilmi-keepalive
interface ATM0.1 point-to-point
atm route-bridged ip
bridge-group 3
pvc 0/101
  oam-pvc manage
  encapsulation aal5snap
interface BVI3
ip address 78.105.x.2 255.255.240.0 secondary
ip address 78.105.x.1 255.255.240.0
ip nat outside
ip virtual-reassembly
interface Vlan3
no ip address
bridge-group 3
None of the rest of my config has anything to do with ATM/DSL or anything else to do with the external interface.
I'm not too concerned about this issue at present. The main issue I guess was that I'm considering upgrading  to a 1921 at some point, which is going to require me running newer  versions of IOS, which had better darn well work!
I'll post the ATM errors I get:
003006: *Jul 28 07:48:05.951 PCTime: ATM0.1(O):
VCD:0x1 VPI:0x2 VCI:0x20 DM:0x100, MUXETYPE:0x0009 Length:0x12
Yep. I (more or less) got that message at the exact point the connection died.
Mine was (something like):
ATM_FCC_GetChannelHandler_PQ2CE: wrong ChannelCode
Yours:
OK so it's slightly different to yours, but I don't think this matters because the CPU in the 877 is MPC8272, which has no UCCs, so instead the DSL chips are connected to an older style FCC, so I'd fully expect this small difference in output
Given that we're not running the same code at this lower layer, this to me, points an even fatter finger at the higher level ATM code.
Matthew Millman wrote:
interface ATM0
no ip address
bridge-group 3
pvc 0/101
  oam-pvc manage
interface BVI3
ip nat outside
interface Vlan3
no ip address
bridge-group 3
You have a mixed-up incorrect configuration. With "atm route-bridged ip" you can have IP address and  NAT statement directly under atm subinterface, does not need a BVI interface and does not need IRB statements. If doing so, remember toalso  change nat statements accordingly.
Otherwise, "atm route-bridged ip" is not needed. That may be the case where you have hosts with a public address on VLAN3.
Note, I don't claim these changed will fix your issue, but if you have to go to the TAC with a bug report, you must go with a clean configuration.
VLAN3 acts as a poor-mans DMZ. It has a number of hosts with public IP addresses.
I've removed the "atm route-bridged ip" statement, which was a hangover from and older setup.
I'm pretty skeptical, but not too arrogant to give it another go. Next time I can afford some downtime, I'll boot it up with 15.1 again with that statement removed, see what happens.
OK-- Tried 15.1(4)M1 and 15.0(1)M5 without "atm route-bridged ip" The VC lasted all of about 15 seconds. So that wasn't the problem.
I can now say that an easy way to see if the release you're running has this problem is within the "show dsl interface atm0" command.
Releases which output this:
Serial Number Near:    FCZ1426C2H 877-M-K9 15.1
Are bust.
Are OK.
I have tried various 12.x and 15.x IOS on both 870 and 880 models and that doesn't improve at all.
Like I said, I have opened a TAC and that's not going all too well. Tried different IOS and DSL firmwares, all with the same result: BadChannel errors and a drop of the line.
I'm wondering where this is going...'cause it looks like a needle in a haystack.
Small update:
The ISP has lowered the speed of the connection from 8 to 6 Mb. Also I have uploaded c880data-universalk9-mz.150-1.M7.bin as advised by the Cisco tech working on this case.
Unfortunately it's not possible to pinpoint which change made the difference, but the line is in sync for 24 hours now, the first time since the problem arose.
Crossing my fingers...
