Configuring Routing with Switch Module SM-ES3-24P
Bhavesh Patel
We have Cisco 3945 Router with SM-ES3-24P Switch Module. when we tried to configure routing in Router and Layer 3 ports on Switch module, the inter-communicaiton is not working?
Please inform how we can use routing in 3945 with SM-ES3-24P module?
Bhavesh Patel
cadet alain
Have you enabled ip routing? sh ip route will tell you it ain't the case if it's empty otherwise try this way:
leave the ports as L2 and create SVI for each vlan then put L2 ports as access ports in the correct vlan.
eg:
ip routing
int vlan 10
ip add 192.168.10.1 255.255.255.0
int vlan 20
ip add 192.168.20.1 255.255.255.0
int vlan 30
ip add 192.168.30.1 255.255.255.0
int f1/0
sw mode access
sw access vl 10
int f1/1
sw mode access
sw access vl 20
int f1/1
sw mode access
sw access vl 30
Regards.
Alain.
Marwan ALshawi
Create L3 Vlan interface
Then Assign each port to the desired Vlan
