ATM Question
acorbett
Hello - this may just be a provisioning issue with AT&T, but I want to make sure all my ducks are in a row. I have a 2691 with two ATM/T1 links going into a VWIC-2MFT-T1. They are configured in a IMA group. I have added a VWIC2-2MFT-T1 and brought in 2 more ATM/T1 links andplugged them in. I have green lights on the card, but the 2 new ATM interfaces(0/1 and 0/2) are down. All 4 controllers are up, but only the 2 original ATM links are up. Here is how I have it configured. Am I missing something?
network-clock-participate wic 2
network-clock-participate aim 0
network-clock-select 2 T1 0/3
ip cef
controller T1 0/1
mode atm aim 0
framing esf
linecode b8zs
controller T1 0/2
mode atm aim 0
framing esf
linecode b8zs
controller T1 0/3
mode atm aim 0
framing esf
linecode b8zs
description VZ Local Loop
controller T1 0/4
mode atm aim 0
framing esf
linecode b8zs
interface ATM0/1
no ip address
ip nbar protocol-discovery
ip route-cache flow
no scrambling-payload
ima-group 1
atm ilmi-keepalive
interface ATM0/2
no ip address
ip route-cache flow
ima-group 1
atm ilmi-keepalive
interface ATM0/3
description AT&T ATM T-1
no ip address
ip route-cache flow
ima-group 1
atm ilmi-keepalive
interface ATM0/4
no ip address
ip route-cache flow
ima-group 1
atm ilmi-keepalive
interface ATM0/IMA1
no ip address
ip route-cache flow
load-interval 30
atm ilmi-keepalive
interface ATM0/IMA1.40 point-to-point
ip address X.X.X.X 255.255.255.252
no snmp trap link-status
pvc 1/40
vbr-nrt 3072 3072
tx-ring-limit 5
oam-pvc manage 5
service-policy output ATM_voip
wochanda
Level 4
Level 4
Tough to tell here what the issue is. If the controllers are up, and we dont see any errors in 'show controllers t1 0/3', our L1 is probably fine.
The next thing we need is to get IMA up on these links. Has the provider confirmed they've configured these links to be in the same IMA group? To get more information, take a look at 'show ima int a0/ima1 detail'. This will break down what is going on with each IMA link, and give you a reason why a link is down.
Most of the time if you see this you just need to ask the provider to restart the IMA group on their switch.
Thank you for the quick response. I think you are right. 'show ima int a0/ima1 detail' shows 'Fe Tx/Rx state notInGroup/notInGroup' for both those new ATMs.
