atm session timeout
ciscoenter
hi all,
i would ask u some information about my problem. Recently i added to my network a ls1010 on top of my 7200 bras as collector for my xdsl. I noticed a strange problem on one of 7200s. Sometimes adsl goes down, cd led is still light on but it doesn't work until i don't shutdown the pvc on 7200.
I think the problem is connected to lcp timeout or something similar.
Someone can help me?
could be a bug in IOS, which version are you running on your 7200 ? Can you post the configs of your 7200 and the LS1010 ?
GP
7200 IOS c7200-js-mz.124-1a.bin
LS1010 IOS ls1010-wp-mz.121-26.E2.bin
7200 config
interface ATM1/0
no ip address
load-interval 30
class-int ppp-atm
no atm auto-configuration
no atm ilmi-keepalive
no atm address-registration
no atm ilmi-enable
range POOL-01 pvc 10/100 10/400
encapsulation aal5mux ppp Virtual-Template10
range POOL-02 pvc 10/401 10/800
and so on
interface Virtual-Template10
ip unnumbered Loopback10
ip tcp header-compression
no snmp trap link-status
peer default ip address pool telecommuters
ppp authentication pap
LS1010 config
interface ATM3/0/2
description LINK ATM1
no ip address
logging event subif-link-status
atm pvc 10 100 interface ATM3/0/0 10 100
atm pvc 10 102 interface ATM3/0/0 10 102
atm pvc 10 103 interface ATM3/0/0 10 103
atm pvc 10 104 interface ATM3/0/0 10 104
atm pvc 10 105 interface ATM3/0/0 10 105
atm pvc 10 107 interface ATM3/0/0 10 107
and so on for every pvc
do u need other piece of configuration?
thanks
I posted the configuration...can somebody help me please? thanks
I have a same problem
I defined a pvc range in my BRAS,sometimes users can't establish a connection until i clear pvc range and define it again.
when this problem occur my link and line protocol is up
i use a SURPASS hiX 5300 DSLAM
and my IOS is c7200-a3jk8s-mz.122-12.bin
please tell me what's the problem and why definion of pvc range again solve the problem?
here is my config :
vpdn-group 1
accept-dialin
protocol pppoe
virtual-template 1
call rsvp-sync
bridge irb
interface FastEthernet0/0
ip address *.*.*.* *.*.*.*
duplex full
speed 100
pppoe enable
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface ATM1/0
no ip address
scrambling cell-payload
framing crc4adm
ima-group 0
interface ATM1/ima0
description ----------
ip address *.*.*.33 *.*.*.*
pvc 1/32
protocol ip *.*.*.33 broadcast
protocol ip *.*.*.34 broadcast
range 1 pvc 0/32 0/232
encapsulation aal5snap
protocol pppoe
ip unnumbered FastEthernet0/0
no logging event link-status
peer default ip address pool S-1
ppp max-bad-auth 3
ppp authentication pap chap DSL-Users
ppp accounting DSL-Users
