Auth Radius fallback to Local?
lcaruso
Level 6
Level 6
How do I configure aaa model so that if a local user is defined, the Radius server is not checked or fails auth and reverts to the local user?
For example, if I have
aaa new-model
aaa group server radius RADIUS_AUTH
server 10.10.10.10 auth-port 1812 acct-port 1813
aaa authentication login LocalAuth local
How do I configure line vty 0 4 to do as I described?
Thanks.
2 Accepted Solutions
John Blakley
If you're wanting to allow local users to telnet/ssh into the device but not checked against RADIUS, you can use the following under your vty lines:
line vty 0 4
login authentication
Method could be:
aaa authentication login TELNET local
line vty 0 4
login authentication TELNET
That won't check the RADIUS server ever. You can also do a couple of other things. One would be for it to check your local first, and then fail over to radius:
aaa authentication login TELNET local group radius
Then if the local account doesn't exist, it can fail over to the radius server before failing authentication altogether...
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
If you still want to check the RADIUS when a local user is not found, then you need the following config:
aaa authentication login LOC_RAD local group RADIUS_AUTH
line vty 0 4
  login authentication LOC_RAD
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
John Blakley
line vty 0 4
Method could be:
line vty 0 4
HTH,
John
Thanks much. I'll test that.
line vty 0 4
