PBR Portforwarding not working on Dual ISP
AndersBramsen
Hi there....finaly got this thing allmost working
But I´m not able to point it to my secodary ISP (My other Public IP)
What am i missing? anyone can point me in right dirrection ?
Exapl...if i would like my smtp to work on number 2ISP  it should be somethin like this right?
ip nat inside source static tcp 10.10.10.2 25 interface Gigabit 0 25
But that not working, only when i point it to my cel 0 interface
Is perhaps should mention
ADSL is Gigabit 0
3G is Cel 0
Since there is a dataplan i like to (move) some of the trafic to the slower ADSL, wich has flatrate....Unlimited data
ASA outside 10.10.10.2
Router Vlan1 10.10.10.1
Network inside 192.168.0.10
And asa doing nat i think and VPN
Here is running config
no aaa new-model
no ip source-route
ip cef
no ip bootp server
ip domain timeout 1
no ip domain lookup
ip domain name it-kon.dk
ip name-server 192.168.0.2
ip name-server 208.67.222.222
no ipv6 cef
chat-script gsm "" "AT!SCACT=1,1" TIMEOUT 60 "OK"
license udi pid C819HG+7-K9 sn FCZ1606C0BY
controller Cellular 0
gsm sim primary slot 1
gsm failovertimer 7
ip tcp synwait-time 10
no ip ftp passive
ip ssh version 2
csdb tcp synwait-time 30
csdb tcp idle-time 3600
csdb tcp finwait-time 5
csdb tcp reassembly max-memory 1024
csdb tcp reassembly max-queue-length 16
csdb udp idle-time 30
csdb icmp idle-time 10
csdb session max-session 65535
no crypto ipsec nat-transparency udp-encapsulation
interface Cellular0
description To ISP 1 (3G)$FW_OUTSIDE$
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip verify unicast reverse-path
ip nat outside
ip virtual-reassembly in
encapsulation slip
load-interval 60
dialer in-band
dialer idle-timeout 900
dialer string gsm
dialer-group 2
async mode interactive
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface GigabitEthernet0
description Wan port to ADSL
ip address dhcp client-id GigabitEthernet0
ip nat outside
duplex auto
speed auto
interface Serial0
no ip address
shutdown
clock rate 2000000
interface Vlan1
ip address 10.10.10.1 255.255.255.252
ip nat inside
ip policy route-map reroute10traffic
interface Dialer0
encapsulation slip
dialer pool 2
dialer idle-timeout 0
dialer string gsm
dialer persistent
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 600 life 86400 requests 10000
ip dns view default
domain timeout 1
no dns forwarding
ip nat inside source static tcp 10.10.10.2 50 interface Cellular0 50
ip nat inside source static tcp 10.10.10.2 51 interface Cellular0 51
ip nat inside source static udp 10.10.10.2 500 interface Cellular0 500
ip nat inside source static udp 10.10.10.2 4500 interface Cellular0 4500
ip nat inside source static tcp 10.10.10.2 25 interface Cellular0 25
ip nat inside source static tcp 10.10.10.2 443 interface Cellular0 443
ip nat inside source static tcp 10.10.10.2 5567 interface Cellular0 5567
ip nat inside source static udp 10.10.10.2 5881 interface Cellular0 5881
ip nat inside source route-map nat_isp1 interface Cellular0 overload
ip nat inside source route-map nat_isp2 interface GigabitEthernet0 overload
ip route 0.0.0.0 0.0.0.0 Cellular0
ip access-list extended nat_isp1
permit tcp 10.10.10.0 0.0.0.255 any
ip access-list extended nat_isp2
permit ip 10.10.10.0 0.0.0.255 any
access-list 2 remark CCP_ACL Category=2
access-list 2 permit 10.10.10.0 0.0.0.3
access-list 23 permit 10.10.10.0 0.0.0.255
access-list 23 permit any
access-list 101 permit tcp 10.10.10.0 0.0.0.255 any eq www
access-list 101 permit tcp 10.10.10.0 0.0.0.255 any eq 443
access-list 101 permit tcp 10.10.10.0 0.0.0.255 any eq smtp
access-list 101 permit udp 10.10.10.0 0.0.0.255 any eq domain
access-list 101 permit udp 10.10.10.0 0.0.0.255 any eq 5881
access-list 101 permit tcp 10.10.10.0 0.0.0.255 any eq 5567
dialer-list 1 protocol ip list 1
dialer-list 2 protocol ip permit
route-map reroute10traffic permit 10
match ip address 101
match interface GigabitEthernet0
set ip next-hop 95.166.108.1
route-map nat_isp2 permit 10
match ip address nat_isp2
route-map nat_isp1 permit 10
match ip address nat_isp1
match interface Cellular0
control-plane
banner login ^Access for authorized personal only!!!^
line con 0
no modem enable
line aux 0
line 3
exec-timeout 0 0
script dialer gsm
login
modem InOut
no exec
transport input all
rxspeed 21600000
txspeed 5760000
line vty 0 4
access-class 23 in
privilege level 15
logging synchronous
login local
transport input ssh
scheduler allocate 20000 1000
end
cadet alain
provided you want outgoing SMTP as well as other traffic as referenced in ACL 101 to go through the ADSL link, you should do this:
no set ip next-hop 95.166.108.1
no match interface GigabitEthernet0
Regards.
Alain
AndersBramsen
Hi Alain , thx for help..bit the problem is not from insider and out..its the orker Way
Outside to inside
The PBR config you have done is for outgoing traffic not incoming traffic.Inbound traffic engineering can be done with BGP but not on a per traffic type basis, it can also be done with PfR but I've never tried this yet so I'm not aware of the restrictions.
Regards.
Alain
Abzal
Level 7
Level 7
I'm not sure but it seems to me that problem is when  you put Static NAT on both outisde interfaces return traffic fails to  come back. That's why only with one Static NAT entry is working fine. It  just my theory. I can be wrong.
Here is an author had the same (not exactly) problem and a solution was found. You may tru it.
https://supportforums.cisco.com/message/3299022#3299022
I think this link also will be helpful for anyone to understand in what order packets get processed
http://book.soundonair.ru/cisco/ch24lev1sec1.html#ch24table01
Hope it will help.
Best regards,
Abzal
Best regards,
Abzal
