11-01-2017 07:44 AM - edited 03-05-2019 09:24 AM
I have one switch1 model 2960 , linked with switch2 model 2960 .
The link become after some time orange and all users connected to switch2 disconnected for some time and returned automatically
What is the problem , is the problem related to pc connected to switch2 , my virus or what
Solved! Go to Solution.
11-03-2017 07:16 AM
Hello
Just perform this on the switch interconnects:
res
Paul
11-01-2017 09:27 AM
11-01-2017 09:30 AM
there is no configuration , just L2 , All cables is OK
11-01-2017 09:31 AM
is there any command to check the switch2 , which port make high traffic to switch1
11-01-2017 09:46 AM
How are the two switches connected? Is it a port channel with multiple interfaces? If your doing layer 2 only, do you have STP configured? Also to note, Hardware guide for the 2960s states the following for the Port LEDs:
Though there can be other issues as well. There has to be some sort of configuration. Are you saying your two switches are at factory default? Then how is the configuration between the two switches? Please post your config files if possible.
11-01-2017 11:15 AM
also post the output of 'show log' of both switches...
11-01-2017 03:25 PM
Hello
How are the switches interconnected - trunk or access port, if the later make sure stp portfast is enabled?
Check/change the cabling
Can you post the configuration also?
res
Paul
11-02-2017 02:02 AM
switch2 connected to switch1 through one cable not trunk
There is no configuration on both L2 Switches.
11-03-2017 03:22 AM
11-03-2017 04:33 AM - edited 11-03-2017 05:05 AM
Hello
As all these devices are in the same default vlan then all interfaces as subject to broadcast traffic - so it could be the reason why your experiencing the disconnects.
Anyhow can you post the interface statistics please?
show interface x/x
res
Paul
11-03-2017 06:44 AM
Thanks for your support
How to execute this command on 48 ports
Show interface x/x
Is there any command.
11-03-2017 07:16 AM
Hello
res
Paul
11-03-2017 09:44 AM
Sorry as it is
show interface x/x
or show interface 0/3
11-03-2017 09:59 AM
show interfaces FastEthernet0/3
Have you tried setting switch 1 as the root ?
11-03-2017 04:58 AM
try and set the Switch 1 to be the root for Vlan 1:
Switch1(config)#spanning-tree vlan 1 root 1
