Auto QOS cisco 3650 IOS XE 16.6.7
Dhaf54134
Hello Community,
Actually am working for QOS project for Snom phone and Microsoft 365 traffic,
we decided to Mark traffic from the terminal (IP Phone and PC with GPO)
in access layer we have cisco catalyst 1000, then I configured "auto qos trust DSCP" in all interfaces
in distribution layer we have cisco 3650 IOS XE,
 basing to this document, it seems that trust DSCP is default in all input interfaces :
https://www.cisco.com/c/en/us/td/docs/switches/lan/Denali_16-1/ConfigExamples_Technotes/Config_Examples/Misc/qos/m_qos_monitoring.html
So I configured auto qos trust dscp in all uplink interfaces (connected to routers).
Now, am searching the way to verify that all is working as expected
from the 3650, I launched sh policy-map on the uplink interface and I get this result :
sh policy-map interface Gi2/1/4
GigabitEthernet2/1/4
Service-policy input: AutoQos-4.0-Trust-Dscp-Input-Policy
Class-map: class-default (match-any)
54074150 packets
Match: any
QoS Set
dscp dscp table AutoQos-4.0-Trust-Dscp-Table
Service-policy output: AutoQos-4.0-Output-Policy
queue stats for all priority classes:
Queueing
priority level 1
(total drops) 0
(bytes output) 27702801
Class-map: AutoQos-4.0-Output-Priority-Queue (match-any)
0 packets
Match: dscp cs4 (32) cs5 (40) ef (46)
Match: cos 5
Priority: 30% (30000 kbps), burst bytes 750000,
Priority Level: 1
Class-map: AutoQos-4.0-Output-Control-Mgmt-Queue (match-any)
0 packets
Match: dscp cs2 (16) cs3 (24) cs6 (48) cs7 (56)
Match: cos 3
Queueing
queue-limit dscp 16 percent 80
queue-limit dscp 24 percent 90
queue-limit dscp 48 percent 100
queue-limit dscp 56 percent 100
(total drops) 0
(bytes output) 5423
bandwidth remaining 10%
queue-buffers ratio 10
Class-map: AutoQos-4.0-Output-Multimedia-Conf-Queue (match-any)
0 packets
Match: dscp af41 (34) af42 (36) af43 (38)
Match: cos 4
Queueing
(total drops) 0
(bytes output) 0
Class-map: AutoQos-4.0-Output-Trans-Data-Queue (match-any)
0 packets
Match: dscp af21 (18) af22 (20) af23 (22)
Match: cos 2
Queueing
(total drops) 0
(bytes output) 89793136
Class-map: AutoQos-4.0-Output-Bulk-Data-Queue (match-any)
0 packets
Match: dscp af11 (10) af12 (12) af13 (14)
Match: cos 1
Queueing
(total drops) 0
(bytes output) 68
bandwidth remaining 4%
Class-map: AutoQos-4.0-Output-Scavenger-Queue (match-any)
0 packets
Match: dscp cs1 (8)
Queueing
(total drops) 0
(bytes output) 0
bandwidth remaining 1%
Class-map: AutoQos-4.0-Output-Multimedia-Strm-Queue (match-any)
0 packets
Match: dscp af31 (26) af32 (28) af33 (30)
Queueing
(total drops) 0
(bytes output) 0
0 packets
Match: any
Queueing
(total drops) 0
(bytes output) 1596096632
bandwidth remaining 25%
queue-buffers ratio 25
Can any one tell me the meaning of 0 packets after every class-map ?
how can I see the DSCP EF traffic/packets ?
How can I verify that my configuration is working ?
Thanks for your help.
2 Accepted Solutions
johnd2310
Level 8
Level 8
I would recommend you span ports on  the 3650 and capture the traffic using wireshark, to see if your markings are really working.
As for configuring qos, i would recommend you not use auto-qos but use the service policy model. Have a look at the following doc:
https://www.cisco.com/c/en/us/td/docs/solutions/Enterprise/Video/qoscampuscat3x50aag.pdf
The service policy model requires a lot of work up front but gives you a lot of flexibility e.g. you can introduce other vendor switches or switches that do not support auto-qos. You just create you qos map for the network edge once and apply that to all you switches irrespective of vendor.
John
**Please rate posts you find helpful**
first of all, once you have marked a post as 'solved' people usually won't look at it anymore (other than of course to see the solution).
For any additonal questions, you better start a new thread. Either way, did you verify on the Windows clients that that group policy has been implemented and that the DSCP marking is active on the clients (following the procedure below) ?
C:\Windows\system32> gpupdate.exe /force
C:\Windows\system32> gpresult /H "%USERPROFILE%\Desktop\gp.html"
C:\Windows\system32> regedit /e "%USERPROFILE%\Desktop\gp.txt" HKEY_LOCAL_MACHINE\Software\Policies\Microsoft\Windows\QoS
which should render a file similar to this:
[HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\QoS\callbar]
"Version"="1.0"
"Application Name"="Callbar.exe"
"Protocol"="*"
"Local Port"="*"
"Local IP"="*"
"Local IP Prefix Length"="*"
"Remote Port"="*"
"Remote IP"="*"
"Remote IP Prefix Length"="*"
"DSCP Value"="46"
"Throttle Rate"="-1"
The error you are getting is most likely caused by the match statement. You need to match on dscp (I assume you are matching on dscp 46):
class-map match-all Voice
--> match dscp 46
policy-map VOICE
class Voice
bandwidth percent 30
5 Replies 5
Leo Laohoo
qos queue-softmax-multiplier 1200
Enter this command and see if it improve things.
johnd2310
Level 8
Level 8
John
Dhaf54134
When I tried to use access-list to match all DSCP EF traffic
match access-group name COS1
policy-map VOICE
class Voice
int gigabitEthernet 2/1/4
3650G-chantilly-1(config-if)#service-policy output VOICE
I have this unexpected log
Invalid queuing class-map!!! Queuing actions supported only with dscp/cos/qos-group/precedence/exp based classification!!!
"Version"="1.0"
"Protocol"="*"
"Local Port"="*"
"Local IP"="*"
"Remote Port"="*"
"Remote IP"="*"
"DSCP Value"="46"
--> match dscp 46
policy-map VOICE
class Voice
Hi George
Sorry about that, i'll open new discussion next time.
Thanks for the reply, and for demo of system QOS Marking.
