Auto Summarization
gowdakssujan
Capture.PNGOn both Routers R1 & R2.
1)Eigrp enabled.
2)Automatic network summarization is in effect.
R1#sh ip route eigrp
10.0.0.0/24 is subnetted, 4 subnets
D 10.10.13.0 [90/30720] via 10.10.12.2, 00:10:36, FastEthernet0/0
R2#sh ip route eigrp
D 10.10.10.0 [90/30720] via 10.10.12.1, 00:11:23, FastEthernet0/0
D 10.10.11.0 [90/284160] via 10.10.12.1, 00:11:23, FastEthernet0/0
Why there is no summarization??????
9 Replies 9
Giuseppe Larosa
EIGRP performs automatic summarization at major network boundary.
In your case all links use subnets taken from 10.0.0.0/8 Class A major network.
To see auto summarization in action change the network between R1 and R2 to 192.168.1.0/24.
R1 will send 10.0.0.0/8 to R2 and R2 will do the same as a result of change of major network out of respective Fas0/0.
Hope to help
Giuseppe
Is it same with RIPv2?
yes it is the same case with RiPv2 also.
BB
But here 172.16.1.0/24 is not a major network. Still, it is summarizing, Why????
10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
D 10.0.0.0/8 is a summary, 00:03:05, Null0
172.16.0.0/16 is variably subnetted, 2 subnets, 2 masks
D 172.16.0.0/16 is a summary, 00:03:05, Null0
Depends io version you using in the lab, by default old routers autosummarisation turned on.
you can check show ip protocol
if you like to turn off auto summary
config t
router eigrp XXX
no auto summary
and post the show ip route eigrp and show ip protocol information
BB
Am using 2811 router; auto summarization is enabled by default.
R1>sh ip pro
Routing Protocol is "eigrp 10 "
Outgoing update filter list for all interfaces is not set
Incoming update filter list for all interfaces is not set
Default networks flagged in outgoing updates
Default networks accepted from incoming updates
EIGRP metric weight K1=1, K2=0, K3=1, K4=0, K5=0
EIGRP maximum hopcount 100
EIGRP maximum metric variance 1
Redistributing: eigrp 10
Automatic address summarization:
10.0.0.0/8 for FastEthernet0/0
Summarizing with metric 28160
172.16.0.0/16 for FastEthernet0/1
Maximum path: 4
Routing for Networks:
0.0.0.0
Routing Information Sources:
Gateway Distance Last Update
172.16.1.2 90 4793887
R1>sh ip pro
Maximum path: 4
0.0.0.0
1>sh ip rou ei
D 10.0.0.0/8 is a summary, 02:25:05, Null0
D 172.16.0.0/16 is a summary, 02:25:05, Null0
see here "Automatic network summarization is in effect"
turn off " no auto-summary" and try.
BB
Hello gowdakssujan,
this is correct behavior for auto summarization to be triggered it is enough to have an outgoing interface that belongs to a different Major network and 172.16.1.0/24 is part of net 172.16.0./16 even a subnet of a different Major network is seen as a MAjor network transition.
EIGRP is classless and carries subnet masks so having a different Major network or having a subnet of a different Major network is treated in the same way for auto-summarization.
Hope to help
Giuseppe
