back-to-back router connectivity
siddindia
Dear Friend,
I have a testing setup, descriptions are followings:-
1)Two cisco 3845 routers with 5 remote locations with leased line links, connected with serial ports of router each.
2)Both routers are connected with gigabiethernet ports.
3) OSPF routing protocol is used for routing with serial links and gigethernet ports except gigabitethernet ports which is connected back-to-back.
4)Independetly each routers are communication with remote locations and its LAN network.
Test1:
IN back-to-back connected gigabitethernet ports, I am using default routes, but i'm unable to commuicate both routers.
Router-1
Router1(config)#int gigabitethernet1/0
Router1(config-if)#ip add 170.128.0.y 255.255.255.0
Router1(config-if)#no shut
Router1(config)#ip route 0.0.0.0 0.0.0.0 170.128.0.x
Router-2
Router2(config)#int gigabitethernet1/0
Router2(config-if)#ip add 170.128.0.x 255.255.255.0
Router2(config-if)#no shut
Router2(config)#ip route 0.0.0.0 0.0.0.0 170.128.0.y
Test2:
I have tested for back-to-back gigabitethernet ports with ospf routing but not successful.
Router-1
Router1(config)#router ospf 100
Router1(config-router)#network 170.128.0.0 0.0.0.255 area 0
Router-2
Router2(config)#router ospf 100
Router2(config-router)#network 170.128.0.0 0.0.0.255 area 0
Kindly suggest me what need to do on both routers for back-to-back connectivity with gigabitethernet ports, so that my setup will be ready.Your suggestions will be appreciable.
Siddhartha Singh
8 Replies 8
Istvan_Rabai
Level 7
Level 7
Hi Siddhartha,
My supposition is the following:
You may have connected the routers back-to-back on the GigabitEthernet ports using a straight-through patch cable.
Please check the output of the following command on both routers:
show interface GigabitEthernet x/y
Check in the output if both interfaces are in "up up" status.
You should see something similar to this:
"GigabitEthernet x/y is up, line protocol is up"
If not, change the patch cable to a crossover cable.
Cheers:
Istvan
hi Istvan,
I have checked Straight-through cable but in my both testing case i'm unable to ping serial port's IP address.
I have checked gigabiethernet ports in both router, they UP and line protocol is UP.
Siddhartha
smothuku
Level 7
Level 7
Hi sidhhartha ,
directly connected interfaces will ping each other without any route or protocol...remove that default route pointing towards gig interfaces of other router.
you must use cross cable for connecting gig interfaces back to back as both are routers.
Most probably you are using straight cable...
After that paste show int g0/1 output of both the routers...
instead of giving whole the subnet give /32 network and check it once...
Cheers
MSK :)
hi MSK,
I'm not getting you in last lines.
"After that paste show int g0/1 output of both the routers...
instead of giving whole the subnet give /32 network and check it once... "
Please clear it
Cheers,
Siddhartha
Hi MSK,
Its true i'm using straight cable.but i'm pinging directly connected gig port.
The problem is in routing.i'm not able to ping any serial ports of another router from one router even i'm using default routing or dynamic routing.
What can i do, so that my routing will be perfect.
cheers,
Siddhartha
Hi ,
Can you paste the config of the routers......
MSK :)
Hi MSK,
I'm sending "show config" output with attachment.
I've tested straight cable and cross cable between both routers through gigethernet ports.Ports will UP in both cases.
I'm still facing problem of routing, unable to ping serial ports from other router.
I think there is issue of routing of back-to-back connectivity.
Kindly help me.
Siddhartha
Siddhartha
Hi Siddhartha ,
Try with below config :
interface Tunnel12
description GRE tunnel between FHQ and Tekanpur
ip address 192.168.11.2 255.255.255.0
qos pre-classify
tunnel source Serial1/0
tunnel destination 10.10.90.1
crypto map VPN-slc
interface GigabitEthernet0/0
description BACK-TO-BACK
ip address 170.128.0.9 255.255.255.0
ip ospf message-digest-key 1 md5 BSF_AMS
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
ip address 200.100.1.1 255.255.255.0
duplex auto
speed auto
media-type rj45
interface Serial1/0
description SilchAR
--More-- ip address 10.10.90.2 255.255.255.0
encapsulation ppp
serial restart-delay 0
crypto map VPN-slc
ip access-list extended VPN-slc
permit icmp 0.0.0.0 255.255.255.0 0.0.0.0 255.255.255.0
permit gre host 10.10.90.2 host 10.10.90.1
second router :
interface Tunnel12
ip address 192.168.11.1 255.255.255.0
qos pre-classify
tunnel destination 10.10.90.2
crypto map VPN-TKP
description BACK-TO-BACCk
ip address 170.128.0.10 255.255.255.0
duplex auto
speed auto
media-type rj45
no ip address
shutdown
duplex auto
speed auto
media-type rj45
interface Serial1/0
description Tekanpur
--More-- ip address 10.10.90.1 255.255.255.0
encapsulation ppp
crypto map VPN-TKP
ip access-list extended VPN-TKP
permit gre host 10.10.90.1 host 10.10.90.2
You need to do extend ping for serial interfaces as crypto map is applied to these interfaces.....
you can do normal ping for back-to-back connected g0/0 interfaces
MSK :)
