Bad magic number in chunk header (7206VXR)
pverstegen
Does anyone know this is a bug ?
Cisco IOS Software, 7200 Software (C7200-IK9S-M), Version 12.3(14)T2
%SYS-2-CHUNKBADMAGIC: Bad magic number in chunk header, chunk 0 data 66AFCEE0 chunkmagic 6093EE60 chunk_freemagic 65B248F0
-Process= "<interrupt level>", ipl= 4
-Traceback= 0x607D29A0 0x60941AE0 0x6086C988 0x60190674 0x6019155C 0x60189700 0x609FF67C 0x6090EA14
igorr_usa
it's because of the fragmentation and VFR enabled on the router. Try the workaround. Disable VFR on all interfaces (no ip virtual-reassembly"), or just on these where the command "show ip virtual-reassembly" shows you reassembly count > 0
Virtual Fragmentation Reassembly was enabled on two interfaces which are running NAT. I just turned it off.
Now let's wait for the result !
I'll let you know.
Peter
