Bad memory - wrote zero Error
nedian123
I have a Cisco 2524 Router while booting following Message is being displayed
"Bad memory - wrote zero, read 0xFFFFFFFF at location 0x00000010" .
What is the cause of this Problem ?
Akhtar
pkhatri
Level 11
Level 11
Hi Akhtar,
You get that error message when you have a DRAM SIMM that is not seated properly in its slot. I suggest you open up the chassis and re-seat the SIMM.
The following link has more info on this:
http://www.ciscotaccc.com/core/showcase?case=K19410284
Hope that helps - pls rate the post if it does.
Paresh
pkhatri
Level 11
Level 11
Hi Akhtar,
Paresh
Hi Paresh,
re-seating didn't worked & possibly the SIMM was faulty, but the link was helpful.
Akhtar
