enable to login in pix
amansoi_5
Sir,
Please find enclosed the config of PIX.
I am unable to telnet & http into PIX from 10.192.10.0 . But I am able to ping from 10.192.10.0 segment to 10.225.1.23 .
Can somebody guide on the same where is problem ?
regds,
Aman
spremkumar
Level 9
Level 9
Hi Aman
Can you try changing the telnet command as mentioned below and check ?
no telnet 10.192.10.0 255.255.255.255 inside
telnet 10.192.10.0 255.255.255.0 inside
regds
Sir,
I have tried but not working.
Aman
I am still waiting for reply....
Aman
