Bandwidth division into two LAN
yesenia-m
Level 3
Level 3
Hi team
We need to divide a dedicated 10 Mbps link two LANs for each half of this bandwidth
I have the possible configuration:
          class-map match-all HOTEL_ADMON
          match access-group 100
          class-map match-all GUEST
          match access-group 200
          access-list 100 permit 192.168.10.0 0.0.0.255
          access-list 200 permit 192.168.20.0 0.0.0.255
          policy-map DIV
          class-map HOTEL_ADMON
          bandwidth percent 50
          class-map GUEST
          class class-default
          shape average 10000000
          int gi 0/0
          service-policy output DIV
Do I need anything else or is complete?
Thank you.
Hi, Yesenia,
Try change class-map to class:
policy-map DIV
class HOTEL_ADMON
14 Replies 14
John Blakley
With this config, you're guaranteeing 50 percent of the bandwidth, but you're not keeping either segment from maxing it out. You should try something like this instead:
policy-map DIV
          shape average 5000000
          class-map GUEST
          class class-default
Also, you may want to have something inbound to police traffic coming into the clients. Generally, if you're natting on the router, you'll need to police into the public address that you've natted the connection out as so you can catch the traffic coming back.
HTH,
John
HTH, John *** Please rate all useful posts ***
Hi j.blakey
I'm configuring the router but will not let me configure the following commands, I need some other command to enable these options or a problem with the IOS?
policy-map DIV
Gw_GARDEN_2901(config)#policy-map DIV
Gw_GARDEN_2901(config-pmap)#class-map HOTEL_ADMON
Gw_GARDEN_2901(config-cmap)#?
Class-map configuration commands:
  description  Class-Map description
  exit         Exit from class-map configuration mode
  match        classification criteria
  no           Negate or set default values of a command
  rename       Rename this class-map
thanks for the help
Hi, Yesenia,
policy-map DIV
class HOTEL_ADMON
How I can show the customer that this effectively dividing the bandwidth?, To efficiently execute the command show policy-map int gi 0/0 out, we get:
Gw_GARDEN_2901#sh policy-map int gi 0/0 out
GigabitEthernet0/0
  Service-policy output: DIV
    Class-map: HOTEL_ADMON (match-all)
      0 packets, 0 bytes
      5 minute offered rate 0 bps, drop rate 0 bps
      Match: access-group 10
      Queueing
      queue limit 64 packets
      (queue depth/total drops/no-buffer drops) 0/0/0
      (pkts output/bytes output) 0/0
      bandwidth 40% (40000 kbps)
      shape (average) cir 4000000, bc 16000, be 16000
      target shape rate 4000000
    Class-map: GUEST (match-all)
      0 packets, 0 bytes
      Match: access-group 20
      Queueing
      shape (average) cir 6000000, bc 24000, be 24000
      target shape rate 6000000
    Class-map: class-default (match-any)
      2053638 packets, 1700513757 bytes
      5 minute offered rate 8000 bps, drop rate 0 bps
      Match: any
      Queueing
      (pkts output/bytes output) 62574/11332279
      shape (average) cir 10000000, bc 40000, be 40000
      target shape rate 10000000
Thank you
Yesenia,
First, my apologies for the typo above, it is indeed the command "class" that goes under the policy map. Second, the only thing that I'm aware that you can do is show them the above output. Can you post the final configuration for your policy?
HTH,
John
Hi John
Dont worry , Course this is the configuration of Policy-map:
policy-map DIV
class HOTEL_ADMON
bandwidth percent 40
shape average 4000000
class GUEST
bandwidth percent 60
shape average 6000000
class class-default
The above output is correct?
Thank you
It looks like it You could show them the output for "show policy-map inter g0/0 out" and point out that the measurements are based off of the primary speed of 10Mb.
      0 packets, 0 bytes
      Queueing
      0 packets, 0 bytes
      Queueing
I am curious as to why the Guest class doesn't show a percentage like the Hotel class does. What you could do is generate some traffic to see if it starts to shape. Here's another concern that you'll have. The shape command only works on outbound policy maps which means a user on this subnet sending traffic. If this is the last point that your user goes out before the internet, you'll also want to police traffic inbound going toward that subnet. If you're natting on this interface, then you'll need to map an ip to this subnet and then police inbound on the public address that you've natted to. Does this make sense?
HTH,
John
I requested that the network had 60 guests some bandwidth, covering the nat is this?
GigabitEthernet0/1.10 interface
  EQUIPMENT_HOTEL description
  encapsulation dot1Q 10
  ip address 192.168.10.1 255.255.255.0
  no ip redirects
  no ip unreachables
  no ip proxy-arp
  ip nat inside
  ip virtual-reassembly in
GigabitEthernet0/1.20 interface
  EQUIPMENT_GUEST description
  encapsulation dot1Q 20
  ip address 192.168.20.1 255.255.255.0
  no ip redirects
  no ip unreachables
  no ip proxy-arp
  ip nat inside
You have nat enabled on the inside. Do you have public addresses that were assigned to you? If so, you'll want to nat your guests out a different public address than what the hotel does. If that's the case, then you'll apply your guest network to a pool of addresses that you can use (one address is enough) and then you can police back in on the public side interface to that address that you've assigned to the guest network. That way the guest network won't be able to download more than 60Mb and send out (shaped) at 60Mb.
John
I mean do I have to create another nat to output the guest network? have two public IP network one for the hotel's own teams and one for the guest network? it currently has a pat configured: ip nat inside source list 1 interface GigabitEthernet0 / 0 overload
In order to control the guest side, you'll need to know what address it's going out as. In order to do that, you'll nat your guest internal subnet out as a certain address. Suppose you have 5 addresses 1.1.1.1 - 1.1.1.5. Your router gets 1.1.1.1. If you're natting everything out the g0/0 (where assumed 1.1.1.1 is assigned), then your hotel and guest both look like they're coming from 1.1.1.1. You wouldn't want to police the traffic to a certain speed, say 60% inbound, to this address because it would also affect the hotel side as well.
Instead, what you should do is create a nat pool for the hotel and guest side, or at least the guest side:
ip nat pool Guest 1.1.1.2 1.1.1.2 prefix 29
ip access-list ext Guest
permit ip 192.168.20.0 0.0.0.255 any
ip nat inside source list Guest pool Guest overload
Now the outbound traffic from the Guest side is seen as 1.1.1.2 and the Hotel side is seen as 1.1.1.1. Now it's easier to police the return traffic:
access-list 101 permit ip any host 1.1.1.2
class-map PoliceGuest
match access-group 101
policy-map PoliceInbound
class PoliceGuest
police cir percent 60
int g0/0 (assuming WAN facing)
service-policy input PoliceInbound
I haven't seen the WAN interface yet, so I'm assuming your outbound policy is configured there as well. If that's the case, you'll have one output and one input on the WAN interface. The policing would only happen to the public address that the guest side goes out of.
HTH,
John
**** Please rate useful posts *****
clear to me thanks! I have to have a public IP for each traffic and so to define both inbound traffic as the output.
I'll do the tests next week and will report how everything went, thank you!
I look forward to hearing the outcome!
Hi J.Blakley,
I'm doing tests again, when placing the command: service-policy output DIV
I check this error:
w_GARDEN_2901 (config-if) # service-policy output DIV
Insufficient bandwidth 10000 kbps bandwidth for the percent (60%) guarantee
In the interface configure: bandwidth 10000, but still will not let me
I leave as was configured:
class-map match-all PoliceGuest
policy-map DIV
  HOTEL_ADMON class
class GUEST
class class-default
class PoliceGuest
interface GigabitEthernet0/0
description INTERNET
bandwidth 10000
ip address 201.X.X.X 255.255.255.248
ip flow ingress
ip nat outside
no ip virtual-reassembly in
duplex auto
speed auto
ip nat pool Guest 201.X.X.X 201.X.X.X prefix-length 29
ip nat inside source list 1 interface GigabitEthernet0/0 overload
know will be happening?
Are correct? Commands I added to the inbound policy?
Thank you
