Cisco 3825 stuck in initial config dialog?
j_friedrich
Hi guys,
     Pardon me for a newbie question.  I have configured the box and done the usual wr, copy run start, and the box keeps coming up with the initial config dialog?
What am I missing?
Thanks for the help.
Jason
turnera
Sounds like maybe your config register setting is not correct.
Boot it up, go through the process and do a show version.
The config register setting should be 0x2102
If it is some value other than that you can change it.
Router#configure terminal
Enter configuration commands, one per line.  End with CNTL/Z.
Router(config)#config-register 0x2102
Router(config)#end
Router#show version
Hope this helps.
http://www.cisco.com/en/US/products/hw/routers/ps133/products_tech_note09186a008022493f.shtml
j_friedrich
Aha,
config register is set to 0x2141.  What should it be set to? 0x2102?
Thanks.
Hi guys,
got it, sorry for the dumb post.  got the values i needed.
Thanks.
Not a dumb post at all, glad ya' got it working.
turnera
Router(config)#end
Router#show version
Hope this helps.
