Bandwidth in SR-TE policy
dundient
Good day everyone
I'm struggling to understand the concept of the Bandwidth in Segment Routing on-demand policy and wanted to clarify some use-cases.
For example, there is a part of config based on IOS-XE.
segment-routing traffic-eng
segment-list name BANDWIDTH_1
index 10 mpls label 16044
index 20 mpls label 16023
segment-list name BANDWIDTH_2
index 10 mpls label 16012
index 20 mpls label 16011
index 30 mpls label 16021
index 40 mpls label 16022
index 50 mpls label 16023
on-demand color 100
authorize
candidate-paths
preference 20
constraints
bandwidth 15000
segments
dataplane mpls
preference 10
explicit segment-list BANDWIDTH_1
constraints
bandwidth 5000
preference 5
explicit segment-list BANDWIDTH_2
constraints
bandwidth 10000
1. What is the purpose of the of bandwidth command in each case? And how can I use them?
2. Is it possible to make a route, for example, BANDWIDTH_1 list takes a primary route with the 5000 bandwidth and after full utilization it goes through BANDWIDTH_2 list?
Thank you in advance
AshSe
Hello @dundient
The bandwidth command in the context of Segment Routing Traffic Engineering (SR-TE) on-demand policies is used to define the bandwidth constraints for a specific candidate path. This is part of the Traffic Engineering (TE) mechanism, where the network can dynamically select paths based on available resources and constraints.
  1. Purpose: The bandwidth command specifies the minimum bandwidth requirement for a path to be considered valid. The SR-TE controller (or headend router) will evaluate the available bandwidth on the links along the candidate path and only select paths that meet the specified bandwidth constraint.
2. The behavior you're describing is not directly achievable with the configuration as it stands. Here's why:
  • The bandwidth constraint in SR-TE on-demand policies is not a dynamic load-balancing mechanism. It does not monitor the actual utilization of the path in real-time. Instead, it evaluates the available bandwidth on the links (as advertised by IGP extensions like OSPF-TE or IS-IS-TE) when selecting a path.
  • Once a path is selected, the router will continue to use that path until a re-evaluation is triggered (e.g., due to a topology change or a failure).
However, you can achieve a similar behavior by using multiple candidate paths with different preferences and bandwidth constraints, as you have configured.
Let me know if you need more detailed analysis of this.
Hope This Helps!!!
AshSe
Forum Tips:
  1. Insert photos/images inline - don't attach.
  2. Always mark helpful and correct answers, it helps others find what they need.
  3. For a prompt reply, kindly tag @name. An email will be automatically sent to the member.
