Bandwidth Point
Ajay Raj
Can someone please explain me what is the meaning of Bandwidth point in Cisco 7206 router
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Basically, it's just a Cisco measurement how demanding (bandwidth?) different 7200 module cards are.
Cisco sets a (it's supported) limit, on maximum bandwidth points for a set of module cards, per bus (left/right module card slots).
If you exceed the supported capacity, the IOS will tell you it's not a supported (hardware usage) configuration.  However, it may, or may might work.  If it doesn't work, well it just doesn't.
