Eigrp over frame-relay
PLC
Hi! I am studying for my CCNA and need some help.  I am configured frame relay mulipoint over eigrp psuedo broadcast in a hub and 3 spoke topology. hub can ping accross to all spokes but spoke are unable to ping each other. I disable spilt horizon on hub and disabled auto summary on all routers. any suggestions? doing sho ip route i see the routes on the spokes for each other.
Thanks for you help!
5 Replies 5
Richard Burts
How are the spoke routers configured on their frame relay interface?
What is in the frame relay map of the spoke router?
Rick
Rick
Thank you guys so much for responding. Here are my configs:
HUB R1
nterface Serial5/0
 no ip address
 encapsulation frame-relay
 serial restart-delay 0
 no fair-queue
 no frame-relay inverse-arp
interface Serial5/0.1 multipoint
 ip address 172.168.1.1 255.255.255.248
 no ip split-horizon eigrp 32
 frame-relay map ip 172.168.1.2 101 broadcast
 frame-relay map ip 172.168.1.3 103 broadcast
 frame-relay map ip 172.168.1.4 104 broadcast
router eigrp 32
 network 10.1.0.0 0.0.255.255
 network 172.168.1.0 0.0.0.7
 no auto-Gateway of last resort is not set
     172.168.0.0/29 is subnetted, 1 subnets
C       172.168.1.0 is directly connected, Serial5/0.1
     10.0.0.0/24 is subnetted, 12 subnets
D       10.3.1.0 [90/2297856] via 172.168.1.3, 02:03:17, Serial5/0.1
C       10.1.3.0 is directly connected, Loopback2
D       10.2.1.0 [90/2297856] via 172.168.1.2, 02:22:09, Serial5/0.1
C       10.1.2.0 is directly connected, Loopback1
D       10.3.3.0 [90/2297856] via 172.168.1.3, 02:03:17, Serial5/0.1
D       10.2.2.0 [90/2297856] via 172.168.1.2, 02:22:09, Serial5/0.1
C       10.1.1.0 is directly connected, Loopback0
D       10.3.2.0 [90/2297856] via 172.168.1.3, 02:03:17, Serial5/0.1
D       10.2.3.0 [90/2297856] via 172.168.1.2, 02:22:09, Serial5/0.1
D       10.2.4.0 [90/2297856] via 172.168.1.2, 02:22:09, Serial5/0.1
D       10.3.4.0 [90/2297856] via 172.168.1.3, 02:03:18, Serial5/0.1
C       10.1.4.0 is directly connected, Loopback3
Spoke R2
interface Serial5/0
 no ip address
 no fair-queue
 ip address 172.168.1.2 255.255.255.248
 frame-relay map ip 172.168.1.1 102 broadcast
NewYork#sho run | begin eigrp
router eigrp 32
 network 10.2.0.0 0.0.255.255
 no auto-summary
D       10.3.1.0 [90/2809856] via 172.168.1.1, 04:01:21, Serial5/0.1
D       10.1.3.0 [90/2297856] via 172.168.1.1, 04:25:42, Serial5/0.1
C       10.2.1.0 is directly connected, Loopback0
D       10.1.2.0 [90/2297856] via 172.168.1.1, 04:25:42, Serial5/0.1
D       10.3.3.0 [90/2809856] via 172.168.1.1, 04:01:21, Serial5/0.1
C       10.2.2.0 is directly connected, Loopback1
D       10.1.1.0 [90/2297856] via 172.168.1.1, 04:25:42, Serial5/0.1
D       10.3.2.0 [90/2809856] via 172.168.1.1, 04:01:21, Serial5/0.1
C       10.2.3.0 is directly connected, Loopback2
C       10.2.4.0 is directly connected, Loopback3
D       10.3.4.0 [90/2809856] via 172.168.1.1, 04:01:23, Serial5/0.1
R3 Spoke
interface Serial5/0
 no ip address
 no fair-queue
 ip address 172.168.1.3 255.255.255.248
 frame-relay map ip 172.168.1.1 301 broadcast
router eigrp 32
 network 10.3.0.0 0.0.255.255
 no auto-summary
C       10.3.1.0 is directly connected, Loopback0
D       10.1.3.0 [90/2297856] via 172.168.1.1, 04:06:57, Serial5/0.1
D       10.2.1.0 [90/2809856] via 172.168.1.1, 04:06:57, Serial5/0.1
D       10.1.2.0 [90/2297856] via 172.168.1.1, 04:06:57, Serial5/0.1
C       10.3.3.0 is directly connected, Loopback2
D       10.2.2.0 [90/2809856] via 172.168.1.1, 04:06:57, Serial5/0.1
D       10.1.1.0 [90/2297856] via 172.168.1.1, 04:06:57, Serial5/0.1
C       10.3.2.0 is directly connected, Loopback1
D       10.2.3.0 [90/2809856] via 172.168.1.1, 04:06:57, Serial5/0.1
D       10.2.4.0 [90/2809856] via 172.168.1.1, 04:06:57, Serial5/0.1
C       10.3.4.0 is directly connected, Loopback3
D       10.1.4.0 [90/2297856] via 172.168.1.1, 04:07:01, Serial5/0.1
Thanks for the additional information. your problem is that the spokes have map entry only for the hub but not for other spokes. You need to add map entries for the other spokes.
rick
Rick
ahh so I thought the dlci had to be unique per ip map. Thank you! thank you!
you need these commands on spokes: 201 is hub DLCI and 192.168.100.3 is spoke ip
frame-relay map ip 192.168.100.3 201
Kazim
