Basic Question EIGRP
ThomasBond_2
I have this configuration in a 3750:
interface gi 0/1
ip add 192.168.10.0 255.255.255.0
exit
interface gi 0/2
ip add 192.168.20.0 255.255.255.0
exit
interface gi 0/3
ip add 192.168.30.0 255.255.255.0
SHUTDOWN
exit
router eigrp 100
network 192.168.10.0 0.0.0.255
network 192.168.20.0 0.0.0.255
network 192.168.30.0 0.0.0.255
The network 192.168.30.0 (administratively down) will be known to other routers running EIGRP 100?
Mohamed Sobair
Level 7
Level 7
NO, it will not be know for other Eigrp 100 neighbors.
Mohamed
marcusbrutus
Eigrp advertises networks by checking its own routing table.  If the interface is down then it won't be on its routing table hence it will not be advertised.
The eigrp network command simply tells eigrp which networks/interface will participate in the eigrp process.
