Basic Setup for testing, and it is not passing traffic
dwaynebmw
I'm just testing this Cisco 1921, very basic configuration on a static connection. Works with my other routers that are Cisco... but for some reason the configs I have entered are not working here. Where am I going wrong.?
*** Router Cisco 1921: Info below
Router#show ver
Cisco IOS Software, C1900 Software (C1900-UNIVERSALK9-M), Version 15.0(1)M3, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Sun 18-Jul-10 01:47 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M9, RELEASE SOFTWARE (fc1)
*** Here is my basic configuration, as you can see 0/0 is WAN and 0/1 is my LAN
DHCP works fine on my side, just not passing traffic...  see below.
! My Network Configs at home
config t
interface GigabitEthernet0/0
ip address 221.254.158.60 255.255.255.248
no cdp enable
no shut
end
config t
interface GigabitEthernet0/1
ip address 10.10.10.1 255.255.255.0
no shut
end
! ---------configure DNS-----------------------
config t
ip domain-name zeta1.local
ip route 0.0.0.0 0.0.0.0 221.254.158.57
ip domain-lookup
ip name-server 8.8.8.8
ip name-server 8.8.4.4
ip dns server
end
! ----------Configure DHCP--------------
config t
service dhcp
ip dhcp pool zeta1_dhcp
network 10.10.10.0 /24
dns-server 8.8.8.8
dns-server 8.8.4.4
default-router 10.10.10.1
lease 7
ip dhcp excluded-address 10.10.10.200
ip dhcp excluded-address 10.10.10.10
end
Nothing exstravagant just want to be able to pass traffic.
Its probably one or two lines Im missing... right?
Thanks for your help in advanced.
Dwayne
2 Accepted Solutions
here is the basic configuration for Internet connectivity:
service dhcp
dns-server 8.8.8.8
dns-server 8.8.4.4
lease 7
ip domain-lookup
ip dns server
ip nat outside
no cdp enable
ip nat inside
ip nat inside source list 1 interface GigabitEthernet0/0 overload
access-list 1 permit 10.10.10.0 0.0.0.255
Thank you. Will give it a try.
D
10 Replies 10
Julio E. Moisa
Could you please share more details about: "DHCP works fine on my side, just not passing traffic...  see below"
Also I suggest excluded the first IP .1
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
I agree with Julio that we need more details to be able to identify the issue. Among other things the output of show ip interface brief would be helpful. I do not see anything configured about address translation. Is nat configured?
Rick
Rick
Router#show ip int br
GigabitEthernet0/0 221.254.158.60 YES NVRAM up up
GigabitEthernet0/1 10.10.10.1 YES NVRAM up up
Router#
Hi guys thanks for jumping in. Its a very basic setup .
The Wan is static, 221.254.158.60, link is up.
The LAN is 10.10.10.1, the link is up.
No Nat translation are in the configuration as you can see. But I went through the configs in the Cisco guide and nothing was mentioned on NAT if all I'm doing is is a simple internet connection. Richard are you saying some kind of NAT is required to get a basic connection with this router?
I am not sure what guide you are referring to but I am guessing that it describes basic configuration of an IOS router where both interfaces are using private addressing (network 10.0.0.0 etc). In that situation there is no need for nat.
But if your LAN is 10.10.10.0 and your WAN is 221.254.258.60 then absolutely someone must provide nat for this to work. It could possibly be on the provider router. Did the provider say that they would translate addresses for you? If they are not doing translation then they assume that you would be doing translation.
Rick
Rick
There is a fairly simple test that you can do that would help clarify the issue.
1) from the router ping some Internet resource (something like ping 8.8.8.8
2) assuming that this ping is successful then you have validated your interface configuration, your routing, and your connection to the provider.
3) from the router ping that same Internet resource and this time specify that the source address is 10.10.10.1
4) if that ping fails it is pretty convincing evidence that the problem is using private addresses to access the Internet and that you need to configure nat.
Rick
Rick
Based on this configuration, best guess, what NAT translations are missing
from my configuration? Any sample would be appreciated.
Thank you
D
Dwayne
Thank you for posting back to the forum and letting us know that you do now have it working. Thank you for marking this question as solved. This will help other readers in the forum to identify discussions that have helpful information.
Rick
Rick
service dhcp
dns-server 8.8.8.8
dns-server 8.8.4.4
lease 7
ip domain-lookup
ip dns server
ip nat outside
no cdp enable
ip nat inside
D
Yep that did it!! Thanks Georg! Now for the fun part. Locking it down with firewall protection.
