Bearer Capability not presently authorized
I am recieving this error when i am trying to test call my own number
This is the error message that i am getting when using debug ISDN q931
debug isdn q931 is              ON.
DSCBL#isdn test call interface s1/0:15 23252112
DSCBL#
*Nov  5 09:33:26.286: ISDN Se1/0:15 Q931: Applying typeplan for sw-type 0x12 is
0x0 0x1, Calling num 23252112
*Nov  5 09:33:26.290: ISDN Se1/0:15 Q931: Sending SETUP  callref = 0x0096 callID
= 0x8018 switch = primary-net5 interface = User
*Nov  5 09:33:26.290: ISDN Se1/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0096
        Bearer Capability i = 0x8890
                Standard = CCITT
                Transfer Capability = Unrestricted Digital
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9839F
                Exclusive, Channel 31
        Calling Party Number i = 0x81, '23252112'
                Plan:ISDN, Type:Unknown
        Called Party Number i = 0x81, '23252112'
*Nov  5 09:33:26.350: ISDN Se1/0:15 Q931: RX <- RELEASE_COMP pd = 8  callref = 0
x8096
        Cause i = 0x82B9 - Bearer capability not presently authorized
Somebody please help me with this cause i am stuck here
Here is the running configuration of the router
DSCBL#sh runn
Building configuration...
Current configuration : 4605 bytes
! Last configuration change at 09:31:46 UTC Mon Nov 5 2012
version 15.1
hostname DSCBL
boot-start-marker
boot system flash c2800nm-ipbasek9-mz.151-1.T.bin
boot-end-marker
card type e1 1
enable secret 5 $1$GRP5$DExBv1hCSO08L.A2SS9Tc.
no aaa new-model
no network-clock-participate slot 1
dot11 syslog
ip source-route
ip cef
isdn switch-type primary-net5
license udi pid CISCO2851 sn FHK1401F1AK
username nangloi password 0 cisco123
username narelamandi password 0 cisco
controller E1 1/0
framing NO-CRC4
pri-group timeslots 1-31
controller E1 1/1
framing NO-CRC4
interface Multilink1
ip address 172.16.31.1 255.255.255.252
ip flow ingress
ip virtual-reassembly
ppp multilink
ppp multilink group 1
interface GigabitEthernet0/0
ip address 192.168.1.101 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 10.10.10.2 255.255.255.252
duplex auto
speed auto
interface Serial0/2/0
bandwidth 2048
no ip address
encapsulation ppp
ppp multilink
interface Serial0/2/1
bandwidth 2048
no ip address
encapsulation ppp
ppp multilink
interface Serial1/0:15
ip address 10.50.10.1 255.255.255.0
encapsulation ppp
dialer map ip 10.50.10.2 name deoli broadcast 29914917
dialer load-threshold 100 either
dialer-group 1
isdn calling-number 23252112
ppp multilink
interface Serial1/1:15
no ip address
encapsulation hdlc
interface Dialer1
no ip address
shutdown
interface Dialer2
no ip address
ip forward-protocol nd
no ip http server
no ip http secure-server
ip flow-export version 5
ip flow-export destination 192.168.1.16 9996
ip route 0.0.0.0 0.0.0.0 192.168.1.99
ip route 192.168.3.0 255.255.255.0 Multilink1
ip route 192.168.4.0 255.255.255.0 Multilink1
ip route 192.168.5.0 255.255.255.0 Multilink1
ip route 192.168.6.0 255.255.255.0 Multilink1
ip route 192.168.7.0 255.255.255.0 Multilink1
ip route 192.168.8.0 255.255.255.0 Multilink1
ip route 192.168.9.0 255.255.255.0 Multilink1
ip route 192.168.10.0 255.255.255.0 Multilink1
ip route 192.168.11.0 255.255.255.0 Multilink1
ip route 192.168.12.0 255.255.255.0 Multilink1
ip route 192.168.13.0 255.255.255.0 Multilink1
ip route 192.168.14.0 255.255.255.0 Multilink1
ip route 192.168.15.0 255.255.255.0 Multilink1
ip route 192.168.16.0 255.255.255.0 Multilink1
ip route 192.168.17.0 255.255.255.0 Multilink1
ip route 192.168.19.0 255.255.255.0 Multilink1
ip route 192.168.20.0 255.255.255.0 Multilink1
ip route 192.168.21.0 255.255.255.0 Multilink1
ip route 192.168.22.0 255.255.255.0 Multilink1
ip route 192.168.23.0 255.255.255.0 Multilink1
ip route 192.168.24.0 255.255.255.0 Multilink1
ip route 192.168.25.0 255.255.255.0 Multilink1
ip route 192.168.26.0 255.255.255.0 Multilink1
ip route 192.168.27.0 255.255.255.0 Multilink1
ip route 192.168.28.0 255.255.255.0 Multilink1
ip route 192.168.29.0 255.255.255.0 Multilink1
ip route 192.168.30.0 255.255.255.0 Multilink1
ip route 192.168.31.0 255.255.255.0 Multilink1
ip route 192.168.32.0 255.255.255.0 Multilink1
ip route 192.168.33.0 255.255.255.0 Multilink1
ip route 192.168.34.0 255.255.255.0 Multilink1
ip route 192.168.35.0 255.255.255.0 Multilink1
ip route 192.168.36.0 255.255.255.0 Multilink1
ip route 192.168.37.0 255.255.255.0 Multilink1
ip route 192.168.38.0 255.255.255.0 Multilink1
ip route 192.168.39.0 255.255.255.0 Multilink1
ip route 192.168.40.0 255.255.255.0 Multilink1
ip route 192.168.41.0 255.255.255.0 Multilink1
ip route 192.168.42.0 255.255.255.0 Multilink1
ip route 192.168.43.0 255.255.255.0 Multilink1
ip route 192.168.44.0 255.255.255.0 Multilink1
ip route 192.168.45.0 255.255.255.0 Multilink1
ip route 192.168.46.0 255.255.255.0 Multilink1
ip route 192.168.47.0 255.255.255.0 Multilink1
ip route 192.168.48.0 255.255.255.0 Multilink1
ip route 192.168.49.0 255.255.255.0 Multilink1
ip route 192.168.50.0 255.255.255.0 Multilink1
ip route 192.168.51.0 255.255.255.0 Multilink1
ip route 192.168.52.0 255.255.255.0 Multilink1
ip route 192.168.53.0 255.255.255.0 Multilink1
access-list 101 permit ip any any
access-list 101 permit icmp any any
access-list 107 permit ip any any
dialer-list 1 protocol ip permit
snmp-server community dscb RW
control-plane
line con 0
line aux 0
line vty 0 4
password remote
login
transport input all
scheduler allocate 20000 1000
end
DSCBL#
I would be very grateful if someone can help me resolve this issue....
Raul Ricano
Did you ever figure this out.  I am seeing the same when trying to forward calls all of the sudden.
thanks,
Raul
