Beginner here. For the life of me, I cannot get my Cisco 1841 router to connect to the internet (home lab)
The51stAgent
Hello. I thought with the things I have learned at this point, that I could simply figure out how to connect my 1841 to my ISP router and from there, be able to plug a host in to the one free fast ethernet port on my router and reach the web. But this has been driving me crazy for over a week. I read other guides online for this but nothing is working, so forgive me for asking what may be a tired question. I would be very appreciative if anyone could help me. I'm going to slightly alter the Public IP I suppose just for privacy's sake, but here goes:
My ISP router's Public IP is 74.182.7.137 with subnet 255.255.252.0
My ISP router's private IP is 192.168.1.1 with subnet 255.255.255.0
Port Fe0/0 of my Cisco 1841 is set to 192.168.1.2
I have a straight through cable running from one of the ports of my ISP router into interface Fe0/0 on my Cisco 1841 router. Shouldn't I be able to get this router fully online and plug my laptop into Fe0/1 and reach the web?
I could post running-configs and show ip interface briefs but to be honest, it would probably be a waste of time, as I am sort of spitballing here and am sure I am entering things wrong. Could someone please advise me on the commands needed to make this work? I think I am understanding that one port/interface needs to be configured with an address of the public range and the other needs to be configured with the address of the private range, but I tried this and the most progress I saw was being able to successfully ping 192.168.1.1 and 192.168.1.2 but could not ping any websites from my Cisco router. Should the gateway of last resort be the private address of my ISP router or it's public address? Does my ISP router need to be bridged? Please help! I am so lost and if I can get some guidance on this it would really help things click for me.
Thanks!
Hi @The51stAgent ,
I found a detail in your configuration. Try this change and try again:
interface FastEthernet0/1
 ip address 172.16.0.1 255.255.0.0
 ip nat inside
6 Replies 6
Martin L
the gateway of last resort should be 192.168.1.1
can you ping 8.8.8.8 ? if so, then try ping google.com
other issues:
1. you already have ISP router with NAT, DHCP, DNS, and your ISP is already doing NAT. ISP router's private IPs are being NAT'ted to Private IP.
luis_cordova
Hi @The51stAgent ,
Try this.
Router(config)#ip dhcp excluded-address 172.16.0.1 <-- LAN gateway
Router(config)#ip dhcp pool LAN <-- Address pool for LAN PCs
Router(dhcp-config)#default-router 172.16.0.1
Router(dhcp-config)#network 172.16.0.0 255.255.0.0
Router(dhcp-config)#dns-server 8.8.8.8 <--  dns of google
Router(dhcp-config)#ex
Router(config)#int f0/0
Router(config-if)#ip ad 192.168.1.2 255.255.255.0
Router(config-if)#ip nat outside
Router(config-if)#no shutdown
Router(config-if)#ex
Router(config)#int f0/1 <-- LAN interface
Router(config-if)#ip ad 172.16.0.1 255.255.0.0 <-- LAN gateway
Router(config-if)#ip nat inside
Router(config)#ip route 0.0.0.0 0.0.0.0 192.168.1.1 <-- ISP router's private IP
Router(config)#access-list 1 permit 172.16.0.0 0.0.255.255 <-- List that allows the LAN network
Router(config)#ip nat inside source list 1 interface f0/0 overload <-- Associate the list with the exit interface
Router(config)#do wr
Thank you, guys, for the responses. It's appreciated more than you know. Luis- I entered your suggested configuration but I still cannot reach the web from my host plugged into fe0/1. I can ping 8.8.8.8 without issue, but when I ping google.com, I get "Translating "google.com"...domain server (255.255.255.255)
% Unrecognized host or address, or protocol not running"
This is my show running-config:
router#show running-config
Building configuration...
Current configuration : 1343 bytes
! Last configuration change at 01:00:58 UTC Fri Aug 23 2019
version 15.1
service config
hostname router
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip dhcp pool LAN
 dns-server 8.8.8.8
ip cef
no ipv6 cef
license udi pid CISCO1841 sn FTX150804LK
redundancy
interface FastEthernet0/0
 ip address 192.168.1.2 255.255.255.0
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
 ip nat outside
 duplex auto
 speed auto
interface Serial0/0/0
 no ip address
 shutdown
interface Serial0/1/0
 no ip address
 shutdown
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet0/0 overload
control-plane
line con 0
line aux 0
line vty 0 4
 login
 transport input all
scheduler allocate 20000 1000
end
Hi @The51stAgent ,
 ip nat inside
SUCCESS! Thank you, Luis!! And to the others that responded! You guys all rock!
post the full running configuration of your 1841. What you need is double NAT, of which luis_cordova has given you the settings. You might have missed something...
