06-15-2017 06:04 AM - edited 03-05-2019 08:42 AM
my question comes after reading the following cisco article:
http://www.cisco.com/c/en/us/support/docs/ip/border-gateway-protocol-bgp/13762-40.html
I have a question about this part:Load Sharing When Dual-Homed to One ISP Through Multiple Local Routers, please see the attached diagram
with respect to the path selection process, local preference comes before (preferring ebgp over ibgp routes)
given the output below, I don't understand why R101 ignored the local preference for iBGP route and picked eBGP route
R101# show ip bgp
BGP table version is 5, local router ID is 192.168.12.1
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
* i0.0.0.0 192.168.12.2 100 0 10 i
*> 10.10.13.3 0 0 10 i
Thank you
Solved! Go to Solution.
06-15-2017 11:21 AM
Adding "sh ip bgp 0.0.0.0" output showing that both routes have equal local preference by default. This output was taken before manipulating local preference:
R1#sh ip bgp 0.0.0.0
BGP routing table entry for 0.0.0.0/0, version 3
Paths: (2 available, best #2, table default)
Advertised to update-groups:
192.168.12.2 from 192.168.12.2 (192.168.12.2)
Origin IGP, metric 0, localpref 100, valid, internal
10.10.13.3 from 10.10.13.3 (10.10.34.3)
Origin IGP, metric 0, localpref 100, valid, external, best
06-15-2017 08:25 AM
Actually both routes have equal local preference which is 100 by default. All the route attributes are equal until they reach step 7 and router 101 is selecting an ebgp route over ibgp.
Below is BGP rib with default local preference:
R1#sh ip bgp
* i0.0.0.0 192.168.12.2 0 100 0 10 i
*> 10.10.13.3 0 0 10 I
Route selection changed once I configured higher local preference for routes learning from ibgp neighbor:
R1#sh ip bgp
*>i0.0.0.0 192.168.12.2 0 200 0 10 i
* 10.10.13.3 0 0 10 I
R1#sh route-map
route-map test, permit, sequence 10
Match clauses:
Set clauses:
local-preference 200
R1#sh run | sec bgp
router bgp 11
bgp log-neighbor-changes
neighbor 10.10.13.3 remote-as 10
neighbor 192.168.12.2 remote-as 11
neighbor 192.168.12.2 route-map test in
06-15-2017 11:21 AM
06-18-2017 12:13 PM
I've learnt the lesson : sh ip bgp doesn't show local preference for eBGP routes, subnet parameter needs to be indicated.
I thank you for all your appreciated efforts.
08-24-2019 10:14 AM - edited 07-27-2020 11:43 AM
