Now that I have my 1841 Router fully online through double NATing, why are ping results different between command prompt and IOS?
The51stAgent
Hey guys. I got some help setting up my home lab and getting my 1841 fully online. Now, when I ping www.google.com, I get a perfect response when I do it from command prompt on my host plugged in to my router. But when I ping the exact same thing from within IOS, I get "Translating "www.google.com"...domain server (255.255.255.255) % Unrecognized host or address, or protocol not running." When I ping 8.8.8.8, I get perfect responses from Command Prompt and from IOS.
Why is this? I'm kind of confused. I have double NATing set up, but I'm not sure if it has to do with that or something DNS config-related. Is this normal? Thanks in advance!  Here is my running-config:
router#show running-config
Building configuration...
Current configuration : 1267 bytes
version 15.1
hostname router
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
ip source-route
ip dhcp excluded-address 172.16.0.1
ip dhcp pool LAN
 network 172.16.0.0 255.255.0.0
 default-router 172.16.0.1
 dns-server 8.8.8.8
ip cef
no ipv6 cef
license udi pid CISCO1841 sn FTX150804LK
redundancy
interface FastEthernet0/0
 ip address 192.168.1.2 255.255.255.0
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface FastEthernet0/1
 ip address 172.16.0.1 255.255.0.0
 ip nat inside
 duplex auto
 speed auto
interface Serial0/0/0
 no ip address
 shutdown
interface Serial0/1/0
 no ip address
 shutdown
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface FastEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 192.168.1.1
access-list 1 permit 172.16.0.0 0.0.255.255
control-plane
line con 0
line aux 0
line vty 0 4
 login
 transport input all
scheduler allocate 20000 1000
end
add the line:
ip name-server 8.8.8.8
to the configuration of your router. This is needed for DNS queries originating on the router...
add the line:
Thanks!
balaji.bandi
in order to ping google.com you need to setup dns name
ip domain lookup
make sure user get DHCP with DNS Entries
can you post user ipconfig /all
nslookup google.com output.
BB
