Best Practices for Own APNIC IP pool with Two ISPs
kumarmh91282
Hi All,
I was wondering what is the best practices followed for Enterprise  WAN connections in the following scenario
1) Own APNIC Public IP pool
2) TWO ISPs for Redundancy (Multi-homed)
3)  ISR routers being used for BGP with both the ISPs  (Edge routers)
4) Firewall used behind ISR routers.
What would be the ideal topology in this scenarios, requirement
1) Dual ISP failover and  Load sharing
2) Internal Application  are hosted on internet with 1-to-1 nat
balaji.bandi
Look at the below example BGP Load share between ISP and Failover.
https://www.cisco.com/c/en/us/support/docs/ip/border-gateway-protocol-bgp/13762-40.html
2) Internal Applications are hosted on the internet with 1-to-1 nat
Behind these Routers ?  - you need to Play DNS and hardware LoadBaancers
BB
