Bgp advertise map shows up twice in running config, is this causing my problems?
mahonemb1
I'm troubleshooting my advertise-map and I see it showing up twice in the running config.  When I type the "no" form it removes both instances and when I readd it, it appears twice again.
router bgp 1000
neighbor 10.10.10.2 remote-as 1001
neighbor 10.10.10.2 password 7 XXXXXXXXXXXXXXX
neighbor 10.10.10.2 update-source Loopback0
address-family ipv4
neighbor 10.10.10.2 activate
neighbor 10.10.10.2 send-community
neighbor 10.10.10.2 advertise-map COND_XXXXXX-XX-XXXX_XXX exist-map UP
neighbor 10.10.10.2 route-map IN in
neighbor 10.10.10.2 route-map OUT out
Version 12.2(33)SRB2
Mahesh Gohil
Level 7
Level 7
Hello machael,
It seems like it is kind of bug because it seems illogical. Do you face any problem in advt. due to this?
you can post problem if you have faced any. But I did not find any supporting bug
This is kind of issue with me where i can see fake eigrp config under address-family with 7600/SRB2 but i do not face
any routing issue due to this
Mahesh
The Status never changes to "Withdrawn" when the condintion stops showing up in the BGP table.
Hello Michael,
If you are confident about the config i advise you to log a case with cisco.
Mahesh
