BGP and Route Map
IeSa50839
Hi Community
Is there any command to check which route-map has been used to advertise routes to an iBGP or eBGP neighbor?
Thanks in advance.
in addition to Giuseppe's remarks (and I am not really sure what you are after), but you could also filter the output of 'sh run'.
In this example, the output of:
R1#sh run | include remote-as 2|route-map
would be:
neighbor 192.168.1.2 remote-as 2
neighbor 192.168.1.2 route-map RM out
route-map RM permit 10
Giuseppe Larosa
Hello @IeSa50839 ,
show ip bgp neighbors
it should provide also what route filters are applied to each neighbor if any.
Alternatively you can examine the configuration.
Hope to help
Giuseppe
would be:
Thank you Georg
