BGP and VRF
adam.sellhorn
Level 4
Level 4
I have a question regarding running BGP on a router with two VRF's:
Here is my config:
router bgp xxxxx
no synchronization
bgp log-neighbor-changes
network x.x.x.x mask 255.255.255.x
neighbor x.x.x.x remote-as xxxxx
no auto-summary
address-family ipv4 vrf VRF-2
redistribute connected
redistribute static
neighbor y.y.y.y remote-as xxxxx
neighbor y.y.y.y activate
no synchronization
exit-address-family
This works fine but now I need to add the following lines to the Global-VRF:
neighbor x.x.x.x prefix-list ROUTES_ALLOWED_IN in
neighbor x.x.x.x route-map PREPEND_RM out
When I do this the changes apply to the Global-VRF and VRF-2.
Should the Global-VRF be in it's own address-family? I think this would work but wanted to run it by you folks since this is my first deployment of VRF's and BGP.
Any help would be greatly appreciated.
Thanks.
7 Replies 7
Edison Ortiz
I'm not sure the behavior you are seeing. I applied your configuration here and it remained in the global portion of the BGP configuration. It didn't duplicate the command into the VRF-2.
What exactly are you seeing in your config?
Also, you only have one VRF, the global routing table isn't considered a VRF.
__
Edison.
Thank you for your reply Edison. The problem I was having with the prefix-list and route-map in the global bgp configuration was that it was filtering routes in VRF-2. I have since created a second VRF and configured it as below to get it to work. I am hoping tomorrow to set up the previous config in my lab tomorrow and play around with it.
router bgp xxxxx
no synchronization
bgp router-id xxx.xxx.58.150
no auto-summary
address-family ipv4 vrf VRF-1
redistribute static
neighbor xxx.xxx.242.169 remote-as xxxxx
neighbor xxx.xxx.242.169 activate
no synchronization
exit-address-family
address-family ipv4 vrf Local
neighbor xxx.xxx.249.205 remote-as xxxxx
neighbor xxx.xxx.249.205 activate
neighbor xxx.xxx.249.205 prefix-list ROUTES_ALLOWED_IN in
neighbor xxx.xxx.249.205 route-map PREPEND_RM out
no synchronization
network xxx.xxx.58.150 mask 255.255.255.255
network xxx.xxx.58.151 mask 255.255.255.255
network xxx.xxx.129.0 mask 255.255.255.0
network xxx.xxx.129.32 mask 255.255.255.240
exit-address-family
Good luck and let us know.
__
Edison.
Well now that I have this setup in a lab environment it works fine. You were right Edison. There must have been something that I was overlooking when this was in production. Thanks for looking into this and sorry for wasting your time.
Mohamed Sobair
Level 7
Level 7
just One note:
The Global IPV4 Bgp table is differ from the BGP VPNv4 table.
If you want to apply any Route filtering method you should know where u want it to be applied. As usually Normal BGP IPv4 carried out Between the PE-CE, And VPNv4 is carried out between PE-PE.
Mohamed
I agree Mohamed and thank you for your reply. But in this case the provider terminated two VRFs to me via one T3 seperated by DLCIs so I had to use BGP IPv4 and VPNv4 on the CE.
Mohamed Sobair
Level 7
Level 7
Hi Adam,
Ok, so you are having Internet Service along with a VPN through the same MPLS-VPN Backbone provider.
Configuring per vrf instance on the bgp process shouldnt affect your Global BGP IPv4 config at all, pls double check and update.
Mohamed
