BGP as-path prepend for specific destination
mirage
Dear all,
I have a following topology in my lab:
R1 (as 208097) -- > R2 ISP (as16010)  -- R3 (as 35805)
                                      R4 (as 10101)
I want to
prepend
my announce for AS35805 only with
as-path access-list
and
route-map
like this:
R1
interface FastEthernet0/0
ip address 2.2.2.1 netmask 255.255.255.252
duplex auto
speed auto
router bgp 20809
no synchronization
bgp router-id 1.1.1.254
bgp log-neighbor-changes
network 1.1.1.0 netmask 255.255.255.0
neighbor 2.2.2.2 remote-as 16010
neighbor 2.2.2.2 route-map BGP_OUT_RMAP out
ip as-path access-list 50 permit ^20809 16010 35805$
ip as-path access-list 50 deny .*
ip prefix-list MM seq 10 permit 1.1.1.0/24
route-map BGP_OUT_RMAP permit 10
match ip address prefix-list MM
match as-path 50
set as-path prepend 20809 20809
But it doesn't work
Does it possible?
Using the
AS-PATH
I can change the path from R2 instead of go direct it go through the R1 and R3 AS300
what I do in R2 (backup)
R2#show running-config
Building configuration...
Current configuration : 2114 bytes
upgrade fpd auto
version 15.0
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
no ip icmp rate-limit unreachable
ip cef
no ip domain lookup
no ipv6 cef
redundancy
ip tcp synwait-time 5
interface Loopback0
ip address 2.2.2.2 255.255.255.255
ip address 10.0.0.2 255.255.255.0
duplex half
interface Serial1/0
no ip address
shutdown
serial restart-delay 0
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
interface FastEthernet2/0
ip address 100.0.0.2 255.255.255.0
duplex auto
speed auto
interface FastEthernet2/1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet3/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet3/1
no ip address
shutdown
duplex auto
speed auto
router bgp 100
no synchronization
network 2.2.2.2 mask 255.255.255.255
neighbor 10.0.0.1 remote-as 100
neighbor 10.0.0.1 next-hop-self
neighbor 10.0.0.1 route-map MHM in
neighbor 100.0.0.4 remote-as 400
neighbor 100.0.0.4 route-map MHMb in
no auto-summary
ip forward-protocol nd
no ip http server
no ip http secure-server
ip as-path access-list 100 permit ^300_600$
ip as-path access-list 100 permit ^300_500$
no cdp log mismatch duplex
route-map MHMb permit 10
set weight 500
route-map MHM permit 10
match as-path 100
set weight 1000
route-map MHM permit 20
control-plane
mgcp fax t38 ecm
mgcp behavior g729-variants static-pt
gatekeeper
shutdown
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
stopbits 1
line vty 0 4
login
34 Replies 34
Edson A. Hernandez
The
as-path
filter list should be
ip as-path access-list 50 permit ^$
NO it not possible.
if the AS20809 is origin of prefix then the
as-path
is it
AS-path
only no more
what you can do in using same but in 35805 and here also you need from R2 (in your topology) send multipath hence the AS35805 can use as-prepend IN direction
mirage
R2 is an ISP (in real life), so I unable to change anythig there.
Is there any way to solve my issue?
I want to accept incomming traffic from AS16010, and for any other AS after AS 16010 make this path as backup..
sorry your in your topology can point each AS for each router
and which router you want to configure primary and backup R1 I think
thanks
So, it is not possible in this topology, correct?
You dont answer me,
R1 you want to use primary and backup ?
check below
No,
This device is backup BGP link. But hase an direct access for AS16010. I want to use it only for them (as16010) when another device (not in topology) is active.
I see you edit the post
just want to mention which one need primary and backup
Please, check full topology image.
R5 is a primary router, connected to primary isp. R1 is Backup router, connected to backup isp.
I want to load-balance incomming traffic as follows:
Incomming traffic from AS 35805 and 10101 to  AS 20809 need to receive via AS 34797,  and traffic from AS 16010 ONLY to AS20809 via R1.
For outgoing traffic all is done via local preferene and
as-path access-list
, but my trouble is inbound traffic.
if there is bgp between AS35805/AS10101 and primary ISP AS then it easy
Yes, these AS have BGP connection between
then I will share the solution tonight
MHM
