BGP basic question
The_guroo_2
Level 2
Level 2
Guys can someone plz tell me th eprefix-list config what is le32 means
ip-prefix list 10 permit 192.168.1.0/24 le 32
so if i write
what is the difference
what abt ge concept
Thanks guys
Reza Sharifi
The difference is that
ip-prefix list 10 permit 192.168.1.0/24 is an exact match only for /24
but
ip-prefix list 10 permit 192.168.1.0/24 le 32 matches /24 and all the prefixes up to 32
Reza
Talha Ansari
Hi Reza,
Thanks for your clarification... you are right on the prefix list match up of those specified for /24 and those specified le 32.
Hi Guroo,
Typically le and ge are used in complex scenarios like for example say suppose your router is learning routes of one network but different subnets :
172.168.0.0 /18
172.168.192.0 /24
172.168.193.0 /28
172.168.209.0 /26
and so on
And from the above routes you intend to permit routes whose subnet mask ranges from /18 to /26... so a prefix list can be created as below :
ip prefix-list 10 permit 172.168.0.0/16 ge 18 le 26
And this could be called in some route-map or distribute-list and applied as a filter or used for some manupulation. This would even permit the routes which have subnet mask of /19 /20 and so on till /26.
Hope that helps....
Talha
Message was edited by: Talha Ansari
