BGP Configuration help
chevymannie
Level 4
Level 4
I have no real mentionable BGP experience so I need some help with a config.
Current configuration:
2xASA5510s (Active/Standby) --->3925 Internet Router---->Internet
Going to:
2xASA5510s(Active/Standby)---->3925 Internet Router A----->ISP (Primary)
                                          \---->3925 Internet Router B----->ISP (Backup)
Note:  Only one ISP just different speed connections
We're going to be using BGP to the ISP.  Our goal is to advertise one subnet via BGP over both links using routerA as the primary and routerB only if it fails.  How can should I configure my ASA and the internet routers to accomplish this?
John Blakley
Are you ASAs paired now or does that need to be done as well? Since you have 2 routers, you could configure hsrp on the lan side for the failover piece. The ASA would have 1 default route to the virtual IP. Then under BGP, you can set your route local preferences to be higher on RouterA than on RouterB. Then on RouterB you'd advertise a higher metric to the ISP for the same routes that you'll be advertising with RouterA.
You probably don't need local preferences (for outbound traffic). If you decide to go with hsrp, you'll only have a single active router at a time....
For the router's perspective, you could do something like (assuming you have a 192.168.1.0/24 subnet):
RouterA:
router bgp 1000
network 192.168.1.0 mask 255.255.255.0
neighbor remote-as
RouterB:
ip prefix-list Advertise permit 192.168.1.0/24
route-map Outbound permit 10
match ip address prefix Advertise
set metric 400
route-map Outbound permit 20
router bgp 1000
neighbor remote-as
neighbor route-map Outbound out
The metric that you choose will need to be higher than the metric that router A advertises. The metric controls the inbound traffic.
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
Thanks John.  One more question.  I want to say the ISP gave us two seperate blocks of addresses.  Is it possible to still have failover for the primary IP block?  If so what configuration changes to the above would we need to make.
