FR issue
The_guroo_2
Level 2
Level 2
guys we have a FR service 2Mpbs with 1Mbps CIR.
I have configured the following shaping but client is expersin lot of issues and i can see lot of drops on interface
interface Serial0/0/5
  ip address 172.x.X.X 255.255.255.252
no ip proxy-arp
encapsulation frame-relay IETF
load-interval 30
no fair-queue
frame-relay class 1Mbps
frame-relay traffic-shaping
frame-relay interface-dlci 16
frame-relay lmi-type ansi
map-class frame-relay 1Mbps
frame-relay cir 1024000
frame-relay bc 128000
frame-relay be 128000
frame-relay mincir 1024000
frame-relay adaptive-shaping becn
Guys any issues with map class or anything i have missed secondly i have noticed that before configuration there was a bandwidth command on serial interface 128k will that effect the config shd i change it to 2mbps
thanks
John Blakley
If I remember right, if you don't specify a bandwidth command on the interface it will default to 56k. So you should have bandwidth 2048 on the interface...
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
If the FR  link to the client was set to 128k then has this been upgraded or should still be 128K.
Your statement is saying under normal traffic conditions target access-rate is 1mb provided by the telco and the minimum contracted rate is 1mb also with committed and excessive burts of 128k
At present:
sh traffic shape -  you will see all the pvc's with the same value - is this what you wish?
You can apply the TS on both sides of the link and just to the DLCI instead of apllying it to the whole interface if  that's better solution  for you?
Using a MOC statement:
For 128K -this will perform at it access rate and if congestion is experienced it will slow down to its contracted rate
policy-map pmTS
class class-default
shape average 1024000 128000 128000
shape adaptive 128000
For 1MB- this is set to shape at 1Mb
policy-map pmTS
class class-default
map-class 1mbps
service-policy output pmTS
int ser0/0/5
class 1mbps
sh policy-map inter ser0/0/5
res
Paul
Kind Regards
Paul
