BGP configuration on Nexus 9000
TRACY HARTMANN
I have a Nexus 9000 that I need to add BGP on (we are currently running EIGRP)
I have the feature turned on the Nexus
Feature Name Instance State
bash-shell 1 enabled
bfd 1 enabled
bgp 1 enabled
router bgp 64640
neighbor 10.20.254.108
remote-as 64563
but it won't let me type in any network statements which is what I normally do on my other cisco layer 3 switches
I am assuming I am missing something I need to turn on since the option for network is not even under the router bgp.
Tracy
Harold Ritter
Hi @TRACY HARTMANN ,
The network statement needs to be configured under "address-family ipv4 unicast" or "address-family ipv6 unicast".
router bgp 64640
network x.x.x.x/y
6 Replies 6
balaji.bandi
what is the full model and post-show version?
here is the config guide: you need the correct license
Creating a BGP Instance
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/6-x/unicast/configuration/guide/l3_cli_nxos/l3_bgp.html#29596
BB
Model   cisco Nexus9000 C9372TX chassis
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Copyright (C) 2002-2018, Cisco and/or its affiliates.
All rights reserved.
The copyrights to certain works contained in this software are
owned by other third parties and used and distributed under their own
licenses, such as open source. This software is provided "as is," and unless
otherwise stated, there is no warranty, express or implied, including but not
limited to warranties of merchantability and fitness for a particular purpose.
Certain components of this software are licensed under
the GNU General Public License (GPL) version 2.0 or
GNU General Public License (GPL) version 3.0 or the GNU
Lesser General Public License (LGPL) Version 2.1 or
Lesser General Public License (LGPL) Version 2.0.
A copy of each such license is available at
http://www.opensource.org/licenses/gpl-2.0.php and
http://opensource.org/licenses/gpl-3.0.html and
http://www.opensource.org/licenses/lgpl-2.1.php and
http://www.gnu.org/licenses/old-licenses/library.txt.
Software
BIOS: version 07.64
NXOS: version 9.2(1)
BIOS compile time: 05/16/2018
NXOS image file is: bootflash:///nxos.9.2.1.bin
NXOS compile time: 7/17/2018 16:00:00 [07/18/2018 05:51:19]
Hardware
Intel(R) Core(TM) i3- CPU @ 2.50GHz with 16400304 kB of memory.
Processor Board ID FDO22040WC0
Device name: INHQCO02
bootflash: 53298520 kB
Kernel uptime is 99 day(s), 8 hour(s), 11 minute(s), 10 second(s)
Last reset
Reason: Unknown
System version: 9.2(1)
Service:
plugin
Core Plugin, Ethernet Plugin
Active Package(s):
what license do you have?
BB
Looks like Enterprise
license_FDO22040WC0_24.lic:
SERVER this_host ANY
VENDOR cisco
INCREMENT LAN_ENTERPRISE_SERVICES_PKG cisco 1.0 permanent uncounted \
VENDOR_STRING=<LIC_SOURCE>MDS_PRODUCTION</LIC_SOURCE><SKU>N93-LAN1K9</SK
U> \
HOSTID=VDH=FDO22040WC0 \
NOTICE=<LicFileID>20180320020959000</LicFileID><LicLineID>1</LicLineID><
PAK>N9K-C9372TX-EFDO22040WC0</PAK> \
SIGN=E65BDEE884D6
INHQCO02#
You got the right License, then from the document provide have steps as below ;
SUMMARY STEPS
1. configure terminal
2. router bgp autonomous-system-number
3. neighbor { ip-address | ipv6-address } remote-as as-number
4. (Optional) description text
5. (Optional) timers keepalive-time hold-time
6. (Optional) shutdown
7. address-family { ipv4 | ipv6} { unicast | multicast }
8.(Optional) weight value
9. (Optional) show bgp { ipv4 | ipv6 } { unicast | multicast } neighbors
10. (Optional) copy running-config startup-config
BB
Harold Ritter
router bgp 64640
network x.x.x.x/y
