BGP Configuration
tyagi.vineet
Hi All
I have three sites (A,B,C) connected through MPLS-VPN using protocol BGP with AD 20(EBGP).Site A is our central site and we have secondary link (VSAT),Site A to B and A to C. Now I want to use same protocol for secondary link and traffic should be move through MPLS-VPN while both the link up.
for mpls link config like blow
router bgp 63590
network x.x.x.x mask x.x.x.x
neighbour x.x.x.x remote-as 9829
all the sites (A,B,C) having bgp AS 63590
How to configure secondary link (VSAT) using same protocol ?
7 Replies 7
Edison Ortiz
The VSAT peering would be considered an iBGP as there isn't a provider router in the middle of the connection as the MPLS-VPN.
While eBGP is preferred over iBGP when all attributes are being equal, on this case, the AS_PATH will be shorter on iBGP so those routes will be preferred.
You can configure a route-map on each router and use AS Prepending on routes being advertised for the VSAT neighbor.
router bgp 63590
neighbor [vsat_peer_router] remote-as 63590
neighbor [vsat_peer_router] route-map AS-PATH-OUT out
set as-path prepend 63590 63590
HTH,
__
Edison.
Thanks Edison
I have configured the same but still most of the route are learned by AD200 (iBGP). please help me out.
Try using the local preference / weight attribute to prefer the MPLS routes
router bgp 63590
neighbor < 9829
neighbor route-map local-pref in
route-map local-pref permit 10
set local-preference 120
You need to configure it at both ends
Narayan
Thanka Narayan
but i think this will work when both the routes comming from iBGP.
weight attribute also i have configured but no change. I am thinking whatever attribute i am configuring is not allowed by sevice provider of MPLS-VPN.
am i right or not ?
It should work... can you post your configurations
The Local Preference and Weight attribute is local to your router to make a decision on the routing. It has nothing to do on the Providers MPLS VPN
Narayan
Did you configure the AS Prepend on all VSAT neighbors? Doing it on just one end won't work.
Can you post the portion of the config from the 3 routers ?
Ok, forget AS_PATH prepending. It won't work on this situation as they are iBGP neighbors. Please follow Narayan's advise and use local-preference instead.
Sorry for providing the wrong information before.
__
Edison.
