BGP connection collision
o_dogorshom
I have an eBGP peer that will not be established till a reset the peer about 10 times. I turned on ths BGP debug switch and I found that a message said:
NOTIFICATION is sento to peer x.x.x.x
code 6 (cease).
And the BGP peer will be in Active state for long time and it will return back to Connect state and stuk in this state.
I know the problem of collision is because the both of peers are trying to initiate the connection at the same time and collision will happen.
So I want o know how to solve this problem or how to configure the peer to play only passive or active role.
pkhatri
Level 11
Level 11
Use the following command to configure one side as passive:
neighbor transport connection-mode passive
Hope that helps - pls do rate the post if it does.
Paresh
Harold Ritter
I do not think this is collision related. It rather looks like a bug that I have come across a while ago. What version of code are you running on the IOS side?
Also, the cease code comes with a sub code. Can you please let us know what the subcode is.
Hi Harold, What is the Bug ID, I'm seeing the same thing sporadically on a couple of my routers and I want to see if they are affected. I'm running Code version is 16.3.1a
